Bosch Router Plate - Router Forums
 4Likes
  • 2 Post By TenGees
  • 2 Post By MikeMa
post #1 of 6 (permalink) Old 01-08-2019, 04:41 PM Thread Starter
Default Bosch Router Plate
I finally remembered to write down the P/n of the Bosch router plate...
It's a Bosch RA 1250...
https://www.amazon.ca/Bosch-RA1250-R...SIN=B000VC76MM
It's not metal though; some type of 3/8" phenolic plastic
* I just noticed in that Amazon advert that it's currently unavailable. Maybe discontinued???
DaninVan is offline
post #2 of 6 (permalink) Old 01-09-2019, 10:27 AM
TenGees's Avatar
First Name: Paul
So you weren't dreaming after all. We believed you, Dan... honest.
DaninVan and Danman1957 like this.
TenGees is offline
post #3 of 6 (permalink) Old 01-09-2019, 11:12 AM
MikeMa's Avatar
That is the Rousseau, and they are still available.
https://www.woodcraft.com/products/r...kaAtPkEALw_wcB
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #4 of 6 (permalink) Old 01-09-2019, 02:51 PM Thread Starter
Looks the same but mine's in a Bosch brand package(?).
DaninVan is offline
post #5 of 6 (permalink) Old 01-09-2019, 09:17 PM
Really easy to find these pre drilled in aluminum. Check Kreg, Rockler, Incra, Woodpecker etc. Turns out the following are pretty much in order of cost.
https://www.rockler.com/bench-dog-al...-router-plates
https://www.rockler.com/rockler-alum...-router-plates
https://www.infinitytools.com/woodpe...-router-plates
https://www.incrementaltools.com/INC...lpaluminum.htm You want the MLP690890-AL model pre drilled for the 1617
Get one with the twist lock insert. Easier to remove to change bits. Many brands still have tiny threaded bolts you have to remove to change bits from above. If you get one, go buy a small box of the tiny bolts because if you drop one, chances you'll never find it again.
post #6 of 6 (permalink) Old 01-10-2019, 10:50 AM
MikeMa's Avatar
The Rousseau is frequently rebranded. I think even Grizzly had it available under their brand at one time.
DaninVan and Herb Stoops like this.
-Mike
MikeMa is offline
First mount your router.... SimonHartropp Table-mounted Routing 6 09-08-2015 01:39 PM
For Sale: Kreg Router Plate - New - Kenosha, WI marc82much Woodworking Classifieds 2 04-14-2014 08:04 AM
buying my first router - questions about Bosch router bases in a table achoox4 New Member Introductions 2 11-28-2012 04:10 PM
Building first table-- need advise on router plate gbuy2001 Table-mounted Routing 9 11-04-2009 05:42 PM
Freud Router stjimm General Routing 1 01-03-2009 11:04 AM
