Router Lift using the Depth Stop Method - Router Forums
 7Likes
post #1 of 13 (permalink) Old 02-20-2019, 07:47 PM Thread Starter
Badger120's Avatar
Default Router Lift using the Depth Stop Method
Hi new to the forum so go easy on me please John here from the UK
Seen one or two videos where folk are removing the depth stop gauge on a plunge router and inserting a threaded bolt and coupler so the router can be raised and lowered from the top of the table.
Is this a good way to do it or does it put too much pressure on one side of the router which may cause the parts to snap off?
Also the videos appear to imply that I need to drill a hole thru the base to connect the coupler. Does anyone know of a good video that explains how to do this in detail? The ones I've seen don't explain it very well.
John
Badger120 is offline
post #2 of 13 (permalink) Old 02-20-2019, 08:04 PM
kp91's Avatar
First Name: Doug
You can get an idea from Routerraizer. Before a lot of router makers incorporated the idea into their products, they were the only game in town
Router Raizer
mgmine likes this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 13 (permalink) Old 02-20-2019, 10:31 PM
JOAT's Avatar
First Name: Theo
I find it easier, faster, cheaper, to just lift the router plate off the table router and all. If I want to change to a different bit I have a plate, complete with router and new bit, to pop in.
kp91 likes this.
JOAT is online now
post #4 of 13 (permalink) Old 02-20-2019, 11:27 PM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
I had my large makita router fitted up that way. It even comes with a long phillips head bolt. All you have to do is carefully mark the underside of the plate where the bolt will pass through.
drill a hole just wide enough to let the threaded part slide through.
widen the top side of the hole to allow the phillips head to sink below the top surface. and youre done.
i got fed up with the phillips head quite quickly though as the screwdriver was hard work lifting the weight of the router. So I made my own bolt with a 10 mm nut on the end and used a socket set speed wrench. That worked very well untill I made my own under table lift
sunnybob is online now
post #5 of 13 (permalink) Old 02-21-2019, 08:33 AM
sreilly's Avatar
First Name: Steve
Welcome to the forum John. I'll pass on this one as I went straight to building my router table but also installed a lift. The last time I looked the Jess Em Rout-R-Lift II was $149.00and that was cheap enough not to have to deal with opening the door under the router or lifting the assembly up to make changes. Now it may not be that way on some but I just figured I'd have more accurate control with a finely built lift and have been happy with it since I installed it. See https://www.amazon.com/JessEm-Rout-R...44444569&psc=1 Woodcraft has it as this price as well.
sreilly is offline
post #6 of 13 (permalink) Old 02-21-2019, 08:39 AM
First Name: Art
The lift isn't for changing the bit it's for getting the bit to the exact height. Without a lift, it's a matter of trial and error, with a lift you simply put a piece of wood next to the bit and raise or lower it until the cutter is exactly where you want it. When using a rail and stile set this can be the difference is doing a good job and a botched job.
mgmine is offline
post #7 of 13 (permalink) Old 02-21-2019, 08:43 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
The first shots show how I modified a Ryobi router for above table adjustment and the other two shots show how I made a simple foot operated lift.
Harry
harrysin is offline
post #8 of 13 (permalink) Old 02-21-2019, 12:46 PM Thread Starter
Badger120's Avatar
Thanks for the imput guys. Can't wait to get started on this project
post #9 of 13 (permalink) Old 02-21-2019, 04:05 PM
Hypnotoad's Avatar
First Name: Phillip
I used one of those cheap lifts from Ebay and fitted a crank handle to it, works great and surprisingly it has fine enough adjustment for my needs:
kp91 and graeme.c.payne like this.
Tight fisted old so-and-so!
Hypnotoad is offline
post #10 of 13 (permalink) Old 02-21-2019, 07:10 PM Thread Starter
Badger120's Avatar
Thumbs up
I had looked at those but wasn't sure if they would be strong enough. It looks a much more simpler way of doing the job and will suit my needs perfectly. Thanks
Installed a lift in my Tilting Router Table. Herb Stoops Tools and Woodworking 40 05-11-2020 04:04 AM
Making a Flat-Bottomed Candy Dish using a Router learnexperience Table-mounted Routing 2 12-09-2018 08:51 AM
I built Shop notes router lift paduke Table-mounted Routing 10 01-05-2018 09:06 PM
