Incra Positioner Tune Up - Router Forums
 10Likes
  • 6 Post By gdonham1
  • 2 Post By ger21
  • 2 Post By sreilly
post #1 of 3 (permalink) Old 02-23-2019, 10:07 PM Thread Starter
gdonham1's Avatar
First Name: Guy
Default Incra Positioner Tune Up
I have been using my 25" Incra positioner to make some dovetail drawers. I was having a hard time moving it forward and backward smoothly. I finally bit the bullet today and took the whole thing apart. The lead screw was tarnished looking. The lead screw is the steel screw that moves (microadjusts) and locks the fence into place. I put a brass wire brush on my grinder and moved the lead screw slowly through the wire brush and cleaned up the lead screw. There were no nicks or other buggers on the screw threads but there was some compacted sawdust and it generally looked dark. After i reassembled the lead screw back in to the housing I took a look at the arm that locks the positioner in place. There is about a 1.5" steel piece that locks into the lead screw at half and fully closed position. There was also no nicks but some compacted saw dust on the threads.
After cleaning up everything I put it all back together and it was back to moving smoothly and easily.
It is funny how to can take something for granted and at the most critical time it will fail.
I am back in love with my positioner.
I had cracked the vacuum port on the wonder fence some time ago by crashing the table into something fixed in the shop. I ordered the new parts and have had them for months. So when reassembling the fence system I put the new vacuum port on. It is now back to sucking but in a good way.
Half the time in my shop is spent cleaning and doing maintenance on equipment. Why do the maintenance fairies miss my shop.
gdonham1 is offline
post #2 of 3 (permalink) Old 02-24-2019, 06:13 AM
ger21's Avatar
First Name: Gerry
It's easy to overlook maintenance until things stop working.
My Incra fence is about 25 years old, and I've never cleaned it.
MEBCWD and RainMan 2.0 like this.
Ger
www.cncwoodworker.com
ger21 is offline
post #3 of 3 (permalink) Old 02-24-2019, 09:17 AM
sreilly's Avatar
First Name: Steve
I've gotten to the point now that the last thing I do before leaving the shop is turn off the dust collector. I keep a section of 4" hose (20') with a 2-1/2" reducer and maybe another 15' of 2-1/2" hose to use the vacuum. Reducing that down from the 6" gate it's connected to is a bit of overkill but does a great job. tubes with the floor attachment but that's after cleaning off the surfaces with the brush tool. The shop stays reasonably organized and clean. Of course I went down yesterday afternoon to finally setup my new Narex chisels and had to spend a bit of time compacting the boxes the Incra fence came in as well as the Sawstop router top. By time I was done with those projects both the shoulder and sciatica were acting up. The sciatica acts up after a fews hours of standing. A few hours later and I decided to have a go again managing to get several chisels sharp and ready to go. Most time consuming was flattening the backs. Then clean up and have dinner.
Now my desk is another thing altogether.....It's kinda organized.
Danman1957 and RainMan 2.0 like this.
sreilly is offline
Jessem Mite R Slide mounted to INCRA LS Positioner suds Table-mounted Routing 18 05-08-2015 04:42 PM
Incra Superfence/LS Positioner and Jessem Router Lift FordTrax Table-mounted Routing 5 02-10-2015 02:19 PM
Incra Table and Positioner Buckyoneshot Table-mounted Routing 22 12-29-2014 07:32 PM
Incra positioner dive Hexhead Table-mounted Routing 14 03-06-2012 10:28 PM
Incra LS Positioner and Bosch RA1181 table thistlefly Table-mounted Routing 3 01-05-2009 06:58 PM
