Too many holes in router plate, what are they for? - Router Forums
post #1 of 11 (permalink) Old 04-14-2009, 07:21 PM Thread Starter
First Name: Todd
Default Too many holes in router plate, what are they for?
So I bought a router plate from peachtree and am installing it in my router table as some of you may know from my other posts. I'm wondering what all the holes in the plate are for. I know the ones in the far corner are for the plate levelers, and the ones to the left of the yellow insert are for the starter pin, but how about the others? I didn't get any instructions on how to use the plate. I also got bumper cushions, which I'm assuming go in the other holes in the corner, but what about the 2 in the front and one on the left that are countersunk, and the third one in the lower left corner? And how about the holes in the yellow insert? See the attached picture.
Thanks for the help on this. This is my first router table and I appreciate all the help I've gotten on this forum.
Todd
taa800 is offline
post #2 of 11 (permalink) Old 04-14-2009, 07:39 PM
HI Todd
A long shot
Take a hard look at the web page,,You may have got a return item that someone else has used..I see they are out out stock now..
Router Table Plates / Inserts
Todd
Name:	peach plate.jpg
post #3 of 11 (permalink) Old 04-14-2009, 07:53 PM
dovetail_65's Avatar
First Name: Dovetail
If it is a return it was drilled out very nicely.
dovetail_65 is offline
post #4 of 11 (permalink) Old 04-14-2009, 08:49 PM
kolias's Avatar
First Name: Nicolas
Definitely a return to me, no reason for the 3 holes on the yellow ring
Nicolas
kolias is offline
post #5 of 11 (permalink) Old 04-14-2009, 10:04 PM Thread Starter
First Name: Todd
According to the package it came in, the 3 holes in the yellow ring are supposed to be there, at least that's what the picture on the package shows, so I don't think it's a return.
taa800 is offline
post #6 of 11 (permalink) Old 04-14-2009, 10:12 PM
The holes can make it simpler to pop the ring out.
post #7 of 11 (permalink) Old 04-14-2009, 10:21 PM
RustyW's Avatar
First Name: Rusty
I have the same plate from MLCS. I think holes in the ring are just extra places to put the pin. But you do have a few extra countersunk holes that are not normally there. I agree that it was probably a return.
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline
post #8 of 11 (permalink) Old 04-14-2009, 10:27 PM
I don't think the holes are a big issue in any event. If the plate is flat and fits, then its good. Even if it is slightly cupped up it probably is still good.
post #9 of 11 (permalink) Old 04-15-2009, 05:05 AM
Todd, I can not speak as to why you have the extra holes in your plate. I can tell you the safety guide pin holes will be installed to the right side of your bit, or between you and the bit if you install the plate from front to back. The purpose of these pins is to prevent the wood from being pulled away from you, possibly pulling your hands into contact with the bit.
post #10 of 11 (permalink) Old 04-15-2009, 09:48 AM
Hi Todd
The extra holes in the plate is no big deal, here's a shot of one of my plates that looks like Swiss cheese
Triton Router Base Plate garbo.hunter Triton 10 08-09-2013 09:00 AM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Router Workshop phenolic plate & Route-R-Joint Question haptown Guide Bushings and Templates 6 12-17-2008 07:46 PM
need advice for inserting rosseau router plate into bench dog promax cast iron table sf_basilix Table-mounted Routing 7 02-21-2008 06:00 PM
