Router Starter Pin - Router Forums
 28Likes
post #1 of 19 (permalink) Old 03-04-2019, 08:00 AM Thread Starter
Badger120's Avatar
Default Router Starter Pin
Just a quick question please guys. I want to drill and tap a hole in my insert plate to take a starter pin.
I only have youtube vids to go on here, and I'm guessing from watching a few that the distance between the center of the bit and the center of the pin is around 3 inches.
Wonder if anyone can inform me of the correct distance please before I start drilling.
Badger120 is offline
post #2 of 19 (permalink) Old 03-04-2019, 09:00 AM
I don't know if there is a standard or if it matters John. The pin is just to steady the piece on as you start to touch the bit.
harrysin, OPG3, MEBCWD and 2 others like this.
post #3 of 19 (permalink) Old 03-04-2019, 10:31 AM
RickKr's Avatar
Starter pin hole is about 2.5" from the router centerline on my Bosch RA1181 router table, just outside the tabletop insert. It is located at about 1:30 on the "clock", viewed from directly above.
Rick
Nickp likes this.
"Quality is like buying oats. If you want nice, clean, fresh oats, you must pay a fair price. However, if you can be satisfied with oats that have already been through the horse, that comes a bit cheaper."
RickKr is offline
post #4 of 19 (permalink) Old 03-04-2019, 11:14 AM
Nickp's Avatar
First Name: Nick
Rick
Same for me....but since you are drilling new, check to see if 1:30'ish is good for your pieces...I put another hole at about 3:00 to the bit...
Nick
Nickp is online now
post #5 of 19 (permalink) Old 03-04-2019, 11:17 AM
put in several...
different set backs and locations...
post #6 of 19 (permalink) Old 03-04-2019, 11:18 AM
Nickp's Avatar
First Name: Nick
put in several...
I'm sure it won't be the last...thanks
Nick
Nickp is online now
post #7 of 19 (permalink) Old 03-04-2019, 11:29 AM
Seems to me i got one from Rockler. It was close to 3/8ths diameter, a little over an inch long with a 1/4 thread. 2 for $4.99. https://www.rockler.com/fulcrum-pins...r-table-plates
post #8 of 19 (permalink) Old 03-04-2019, 11:49 AM
JOAT's Avatar
First Name: Theo
I've seen the videos on them, but never saw the need. Never used one, and have never had any problems.
JOAT is online now
post #9 of 19 (permalink) Old 03-05-2019, 08:17 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
I use the fence which is perfect except for a few curved projects.
Harry
harrysin is offline
post #10 of 19 (permalink) Old 03-05-2019, 12:03 PM
OPG3's Avatar
First Name: Otis
I was once in a conversation with one of my employees. I spoke of his use of the starter pin and he said he never uses them - even on freehand work...
I said "Hey - Will you arm wrestle me for $100.00?" He was about twice my size and half my age and I'm certain he could crush my hand.
He turned and was looking for a table or bench and I said, "What you looking for? I'm wanting to do this FREEHAND!" Talk about a puzzled look, he was dumbfounded. I told him that in arm wrestling you need a pivot point - then he understood about the starter pin!
If the FENCE doesn't do the job, then a starter pin is necessary IMHO!
OPG3
Tweak everything!
OPG3 is offline
Bosch router table starter pin jpaskell Table-mounted Routing 28 06-05-2019 09:08 AM
"Kickback" when using a pin router with downcut spiral? dcdc Table-mounted Routing 14 10-14-2015 12:13 PM
Using Your Router For The First Time learnexperience General Routing 0 07-23-2011 09:20 PM
building a Pin Router dane5547 General Routing 36 08-13-2009 02:58 AM
