Stopped Drawer lock joint cut - Router Forums
 1Likes
  • 1 Post By Jim Gallo
post #1 of 10 (permalink) Old 03-08-2019, 07:37 AM Thread Starter
Default Stopped Drawer lock joint cut
Hey all,
Iím building drawers for 2 nightstands and the plans called for 3Ē drawers. However the plans also called for a drawer opening in the apron to be 3 15/16Ē. I have already mad the opening for the drawer front.
My issue is, I can make the stopped cut on the drawer front on one side, but I would have to go left to right on the other side of drawer face, which could prove disastrous. How would I SAFELY go about making the stopped drawer lock cut on both sides of the drawer front?
Thanks for any guidance.
Jim
Sent from my iPhone using Tapatalk
Jim Gallo is offline
post #2 of 10 (permalink) Old 03-08-2019, 01:03 PM
Jim maybe you could post a link to or a picture of the locks so we can see how they mount.
post #3 of 10 (permalink) Old 03-08-2019, 01:06 PM
vchiarelli's Avatar
First Name: Vince
@Jim Gallo - let's make sure we understand what you are trying to do. Are you attempting to make a drawer lock joint on the front/sides of your drawer? If that is the case, why do you need to make it a "stop" joint? If that is not the case, as Chuck said, can you explain it in more detail.
vchiarelli is offline
post #4 of 10 (permalink) Old 03-08-2019, 04:19 PM Thread Starter
Default Stopped Drawer lock cut
Thanks for clarifying what I was trying to describe vchiarelli. That is my issue, the front is taller than the sides and back of the drawer. I received a good technique from the guys at Lumberjocks and Iím going to give that a try in the morning.
Thanks again!!!!
Jim
post #5 of 10 (permalink) Old 03-08-2019, 04:22 PM Thread Starter
The front is taller than the sides and back, and I donít want the profile to be seen on the front of the drawer, above the sides.
post #6 of 10 (permalink) Old 03-08-2019, 05:28 PM
vchiarelli's Avatar
First Name: Vince
Thanks again!!!!
Jim
Thanks for clarifying that Jim - makes sense now that. Care to share the tip you received for the benefit of anyone reading this?
post #7 of 10 (permalink) Old 03-08-2019, 05:40 PM
I got you now Jim. I altered the title of the thread to show that you want to make a stooped joint cut instead of installing a lock mechanism. For the one cut where you need to start at the point where the drawer side will meet I would clamp a stop block on the infeed side of the fence at the right distance to where you want the cut to start and I would put the drawer against it at an angle and swing the drawer front into the bit slowly. The stop block will prevent it from self feeding and you can then proceed from right to left to finish it as normal.
post #8 of 10 (permalink) Old 03-08-2019, 06:44 PM
Make the drawer front 3", cut the corner joint and then glue a 15/16" strip on the top, If you use a thin-kerf blade you should be close to getting the grain to match (assuming that it's going to be stained).
tomp913 is offline
post #9 of 10 (permalink) Old 03-09-2019, 07:18 AM Thread Starter
swarfmaker likes this.
post #10 of 10 (permalink) Old 03-09-2019, 11:16 AM
That's similar to what I said but you'll have to make sure you have good pressure on the push block. If you could clamp a stop behind the push block to make sure it can't move as you start the cut then you'll have all the bases covered.
A Tall Lock Miter Joint Fence for Ken & Sid Stefang Table-mounted Routing 30 06-21-2015 02:50 PM
Garage Overall for Shop TRN_Diesel Workshop Showroom 558 10-24-2010 02:44 PM
Cut both box joint pieces at once? Fretts Jigs and Fixtures 2 06-15-2010 01:17 PM
Dovetail Joint - Drawer Project Kokopelli Jigs and Fixtures 11 04-26-2010 06:32 PM
Drawer Lock Joint jimcrockett Table-mounted Routing 9 07-21-2008 02:02 PM
