Delta shaper top - Router Forums
 1Likes
  • 1 Post By Haze5
post #1 of 4 (permalink) Old 04-03-2019, 05:28 AM Thread Starter
Default Delta shaper top
I have Delta HD shaper top anyone out there think this would work for new router table
Herb Stoops likes this.
Haze5 is offline
post #2 of 4 (permalink) Old 04-03-2019, 10:12 AM
Hi Doug and welcome. It's possible but here's a couple of things to check out and consider. How will you mount the router to it is first and how thick is the hole where the bit will go through. Most cast iron tops are 3/4 to 1" thick. That wouldn't leave you much extension on many small bits. Possibly not even enough to expose the full profile above the table. If you try to thin that part of the table will you compromise table structurally?
Most of us older guys on the forum build our own tables. It's cheaper in the long run and you get what you want that way. Router insert plates are 5/16 to 3/8" thick so you would lose a lot less of the height capacity that way. I've built tables for as cheap as $5-10 by repurposing materials and they aren't that hard to build. There is a very large and long running thread on tables members have built.
post #3 of 4 (permalink) Old 04-07-2019, 09:50 AM
First Name: Art
You should have a way of adjusting the size of the hole in the table to accommodate different size bits. Also, the top would probably be small and you'd find it more useful if it was long in order to give good support on both infeed side and outfeed.
mgmine is offline
post #4 of 4 (permalink) Old 04-07-2019, 12:53 PM
Look at this thread, I posted a couple of years ago on how I installed a plate in my cast iron top.
https://www.routerforums.com/tools-w...ter-table.html
Herb Stoops is online now
Workbench Top Input nickrochon Tools and Woodworking 24 04-01-2013 07:37 PM
What does the back of router table top look like? volunteers Table-mounted Routing 5 07-18-2012 09:54 PM
Newby question on a Rockwell/delta 43502 over arm router shaper lumbertrader General Routing 1 12-29-2010 11:57 AM
For Sale: For sale....Delta bench top bandsaw!!!!!! remoc Woodworking Classifieds 4 06-29-2007 02:18 PM
router table top delroy33 General Routing 18 07-30-2006 04:53 AM
