Triton TRA001 - Router Forums
post #1 of 16 (permalink) Old 04-17-2009, 05:40 AM Thread Starter
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Default Triton TRA001
After reading so much here about the Triton's suitability for use in a router table and having a Triton router table, I decided to get one and was pleased to find one new, in the box, on eBay for Eur99. Last night I was shocked to discover that only 1/2" collets seem to be available for them, unless you are in Japan! No-one seems to have mentioned this in their fulsome praise for the router. For Eur99, I'd put up with it and swap routers if I had to use a 1/4", 8mm or 12mm cutter, but when another bidder came in during the last minute, I wouldn't go above Eur135 and let them have it.
Whilst most of my bits are 1/2", I do have some specialist ones that have other shanks. How come that such a well known router isn't available with other collets? Supplying a 1/4" sleeve with an industrial grade router is hardly a sensible solution. Personally, I wouldn't want to use a sleeve, particularly in such a powerful router.
Cheers
Peter
istracpsboss is offline
post #2 of 16 (permalink) Old 04-17-2009, 08:18 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
"Whilst most of my bits are 1/2", I do have some specialist ones that have other shanks. How come that such a well known router isn't available with other collets? Supplying a 1/4" sleeve with an industrial grade router is hardly a sensible solution. Personally, I wouldn't want to use a sleeve, particularly in such a powerful router."
Peter I just cannot imagine what you have against reducer sleeves, they are precision made and I for one have been using them for many years without any sort of problem. Have you had some personal problem with a sleeve.
Makita who are the Japanese makers of my two big routers have a range of sleeves available for these machines, don't you think that they know what they're doing.
Harry
harrysin is offline
post #3 of 16 (permalink) Old 04-17-2009, 08:45 AM
HI Peter
You may want to check the box one more time ,the one I have came with a collet adapator in the box .. look for a very small plastic bag, it wil also have some extra screws in the same bag ,to hold in the guide plate..
"RPM Range is Infinitely adjustable-8,000 to 21,000 rpms
Collets Included are 1/2" (w/1/4" collet adapator)
http://www.mlcswoodworking.com/shops..._bearings.html
Cheers
Peter
post #4 of 16 (permalink) Old 04-17-2009, 04:00 PM Thread Starter
Country: Croatia
First Name: Peter
Hi Harry
I just always thought of them as having poorer grip than proper collets as they don't grip in the same way. Why would other manufacturers like DeWalt provide proper collets if they could get away with cheaper reducing sleeves?
Cheers
Peter
post #5 of 16 (permalink) Old 04-17-2009, 04:02 PM Thread Starter
Country: Croatia
First Name: Peter
HI Peter
Yes, they do include a 1/4" reduction sleeve.
Cheers
Peter
post #6 of 16 (permalink) Old 04-17-2009, 04:05 PM Thread Starter
Country: Croatia
First Name: Peter
Hi Harry
I just looked at your picture. The reduction sleeve on the right has only got one slit in it and would grip eccentrically.
Cheers
Peter
post #7 of 16 (permalink) Old 04-17-2009, 10:56 PM
harrysin's Avatar
First Name: Harry
Hi Harry
Cheers
Peter
Not so Peter, the gap when tightened is infinitesimal, meaning that 99.9% of the cutter is gripped.
Harry
harrysin is offline
post #8 of 16 (permalink) Old 04-17-2009, 11:03 PM
harrysin's Avatar
First Name: Harry
"Why would other manufacturers like DeWalt provide proper collets if they could get away with cheaper reducing sleeves?"
Manufacturers of many products sell them at little or no profit, relying on accessory or consumables sale for ongoing profit. Good examples are water filters and printers, the former relies on ongoing sales of filter cartridges and the latter on ink cartridges. But who really knows the actual answer to your question Peter, one thing I do know is that there is no problem with router manufacturer's reducer sleeves, if there are Chinese copies out there, that may be different.
Harry
harrysin is offline
post #9 of 16 (permalink) Old 04-17-2009, 11:31 PM
dovetail_65's Avatar
First Name: Dovetail
Well my PC and Milwaukee both came with entirely different collets for each size bit, included with the router, not a little insert.
Actually, all my DeWalt's I have came with two separate collets for 1/4" and 1/2" too.
Only my Hitachi and old Makita came with a insert sleeve collet.
dovetail_65 is offline
post #10 of 16 (permalink) Old 04-19-2009, 02:17 AM Thread Starter
Country: Croatia
First Name: Peter
Hi Harry
I'm sure you've much more experience than I have. If they work for you, it's good enough for me, although I'm still dubious about a single slit collet. Again, why would others go to the greater expense of making multi slit ones if single slit was good enough? I'll have another go laying my hands on a a TRA001.
Cheers
Peter
Triton Router Base Plate garbo.hunter Triton 10 08-09-2013 09:00 AM
Guide Bushings for Triton Router Sliderule Guide Bushings and Templates 8 03-30-2010 10:18 PM
Table for Triton MOF001 socalrascal Table-mounted Routing 3 08-18-2008 06:22 PM
Triton Router to Bosch Router Table question gxbluewave Table-mounted Routing 2 12-26-2007 12:32 AM
Triton router to Bosch Table question? gxbluewave Table-mounted Routing 0 12-25-2007 03:19 PM
