Incra master lift - Router Forums
 6Likes
post #1 of 11 (permalink) Old 04-22-2019, 08:36 PM Thread Starter
Default Incra master lift
Has anyone had this problem? I have a Incra master lift with a Incra cleansweep down draft collection. When I raise or lower the router, the lead screw on the lift is always built up with fine saw dust and you can't raise or lower the router until you blow off the lead screw with air. You have to do thie every time you want to raise or lower the router. This is a real pain. Has anyone experienced this? Would anyone have a solution? I appreciate your help. Thanks...
blacktrain is offline
post #2 of 11 (permalink) Old 04-22-2019, 08:56 PM
your DC is inadequate and/or the air flow for the DC isn't set up as well as itcould be..
post #3 of 11 (permalink) Old 04-22-2019, 09:42 PM
First Name: Randy
Over time, dust and chips do build up on the router and lift mechanism under the Incra table even with the Cleansweep box installed. I would suspect that the previous poster who answered is correct that inadequate dust collection has something major to do with your problem. I always attach the CleanSweep port to my cyclone dust collector instead of the vac I own. The vac, even though one of the best, just doesn't generate enough air volume movement to such the dust right through.
I do get dust buildup on the router lift threads and mechanism but only over a longer period of time. The router lift and router should be pulled out periodically for cleaning maintenance. However, this should not be a problem each time you use it.
Do you use the Incra recommended slotted throatplates with the lift? They improve the air flow a lot and don't interfere with use.
grbmds is offline
post #4 of 11 (permalink) Old 04-22-2019, 10:34 PM
I use the inserts that are larger than the bit to allow air flow through the table besides through the fence. I have the DC wyed to the box below and to the fence.
TenGees likes this.
Herb Stoops is online now
post #5 of 11 (permalink) Old 04-23-2019, 10:48 AM
hawkeye10's Avatar
First Name: Don
Having dust collection on the fence and from below really helps.
Herb Stoops likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #6 of 11 (permalink) Old 04-24-2019, 12:28 AM
gdonham1's Avatar
First Name: Guy
I dont have the Incra Lift but really like Incra Products. Why dont you email support at Incra and ask them about the problem. They have always been very helpful when I contacted them in the past. The Incra staff is small and know their products.
[email protected]
DesertRatTom and Herb Stoops like this.
gdonham1 is offline
post #7 of 11 (permalink) Old 04-25-2019, 07:28 AM
sreilly's Avatar
First Name: Steve
[email protected]
My suggestion as well. In fact you can call and speak to Mark at 1.888.804.6272.
That said while I don't have the Incra lift I do as Herb and have DC at both the fence and lift areas that do an outstanding job. That said I should mention that I have a CV1800 6" DC system and the 6" port feeds a single inlet with 2 - 4" blast gates, one for the fence and the other for the lift compartment. DC makes all the difference.
DesertRatTom and tulowd like this.
sreilly is offline
post #8 of 11 (permalink) Old 04-26-2019, 09:49 PM
Stick has suggested using a snorkle attached to the bottom of the router to improve upward air circulation through the router, to cool the motor. But his would also improve the up-flow through the insert and possibly improve above the table DC.
And, that is a really handsome router table!
post #9 of 11 (permalink) Old 04-29-2019, 08:45 AM
First Name: Randy
Default Dust Collection in the Fence
Dust collection using the port on the Incra Wonder Fence does improve the result, but only when the bit is near or partially buried in the fence. If the bit is completely exposed connection to the fence port is of no use in dust collection.
The slotted throat plates that Incra sells improve downward airflow significantly. They are called the CleanSweep Magnalock Rings.
grbmds is offline
post #10 of 11 (permalink) Old 04-29-2019, 04:29 PM
tulowd's Avatar
First Name: Paul
That is the same table and fence I have, sweet mod on running another extrusion for separating the micro adjuster. Love the stand, that is nicer than the furniture in my meager existence. Tip o' the hat to you, good sir.
I have similar D/C setup as yours, along with a table top dust hood as well. Hoping to start using it soon, once the D/C is connected and everything else is built. The clear router cabinet has 2 blast gates in it to control air flow.
tulowd is offline
Incra PRL-v2 lift Gadget01 Table-mounted Routing 24 02-08-2020 09:57 AM
Inra Lift or Triton Router? Have Incra LS Table Psychbiker Table-mounted Routing 27 09-17-2017 11:54 PM
Incra Superfence/LS Positioner and Jessem Router Lift FordTrax Table-mounted Routing 5 02-10-2015 02:19 PM
Incra Lift Jessam Table stjimm Table-mounted Routing 9 12-24-2012 06:02 PM
