Table saw extension input - Router Forums
 35Likes
post #1 of 30 (permalink) Old 10-28-2019, 08:35 AM Thread Starter
First Name: Steve
Default Table saw extension input
So, I have my grandpas 113.27520 table saw. From the 50's or 60's. I also have his craftsman/ king seeley 103.20660 jointer. It is from the 50's also... I like old stuff. It was family. It was built to last. I went through the jointer, installed a shelix head, it is awesome! Looks better than new. Cuts great. Straight as an arrow.
OK... the table saw was in good shape, just needed a tuneup and a fence. The old fences sucked. So, I checked blade runout, good, aligned blade, installed a forrest blade, and bought a vega pro 40 fence. On that fence, I installed the jessem clear cut stock guides. The rollers are awesome. They mount on a T track, so they are adjustable (as you all know).
To the point. The saw has one 10" extension. (mounted on the right side) I am planning on putting another 10" extension on the left side. If I add a 16" ish router table to the existing 10", that puts me near the end of my vega pro 40. The table is plenty big for my needs. I have made a rigid steel frame on wheels the saw is mounted on. So, the extensions will be supported with adjustable rods (jacks if you wish) to keep the table level, and support the weight.
So, I'd have a 10" extension on the left side, the main table, 10" extension on the right side, then my router table.
Question is... I really only want the table. I don't want a fence. The vega fence is straight. I can put a sacrificial strip on it if I am doing something requiring that. The jessem rollers could be slid off the track, turned 180*, then they roll the right way to feed the router. (does that make sense? just slide them off the T track, rotate, then go). If, in the future, I think I need a more "fancy fence". I can always buy one. The fences with most tables are basic, and fair at best.
I have a triton router, so I do not need a router lift either.
I am contemplating a table with only the insert ring. The other option is a regular table cut out for the lift plate, and spending another 70 to 100 for a plate, or make my own.
I was on the fence between the saw stop table only at 264 ish, or the bench dog table. Then I saw the grizzly with no insert plate, only the cutter insert.
The saw stop is 265, (16 x 27") then I need to buy or make an insert plate. Free shipping
The bench dog (16x27) is 349, fence no plate, or 369, fence and plate. I didn't see an option for table only, nothing else. PLUS rockler will charge me another 20 shipping... even if I ship to store... that just aggravates me. They have a truck show u[ every damn week or so.
The grizzly has only an insert ring, 18"x27", no fence. It is 328 with free shipping. This seems like the most reasonable option for me. The sawstop will be 365 with plate... or more. The rockler is at the same 360+.
So, what do you think? I am not worried about having to drill holes to match up stuff. I am a metal guy.. so no big deal.
My only concern is future needs. IF I buy the grizzly, and down the road I think I need a lift instead of the triton adjustment, another table would be the only option.
I am just an occasional hack. I like metal/ welding/ machining more.. but wood is fun, can make some pretty cool stuff with metal/ wood accents or vice versa. I am not a cabinet maker...
(Oh, btw... I bought a used summerfeld table locally, it was a good price, but I did not think I was going to like it because it was aluminum, and a few other reasons). I don't like it. Not what I wanted. Not that it is a bad piece... just not what I really want. I like old, heavy, cast iron, etc.
Wags
Nickp likes this.
wagspe208 is offline
post #2 of 30 (permalink) Old 10-28-2019, 12:28 PM
There are a number of drawbacks to adding a router into a saw's extension table. Unless you are desperately short of room most of us will tell you don't do it. First is that you can get busy with a routing project and realize that you need to cut some wood with the saw and the router will be in the way. But the router is set to do a job and you don't want to have to reset fence or height. That's an aggravation that tends to take some the fun out of woodworking. Second is that the fence on a router table has to have a cut out in it because most of the bit is usually behind the face of the fence. That means you'll need to add something to your saw fence on that side to accommodate that. Third is that you must feed wood from right to left on a router table and you don't want to be reaching over the bit on either side so the only location where you can do that is at the end of the extension. If you have the room build a separate table or go for a table top model. I have one of each as I find I prefer the table top one for doing small pieces. The bench top model is another 16" or so taller which makes that work more comfortable.
The only real advantage of a lift over a router with above table adjustment is that the lift will lock in position by itself and you will have to reach under the table to lock a router so if that's going to be a problem then you need a lift. Jessem makes good lifts that start at $189. https://www.amazon.com/s?k=jessem+ro...nb_sb_ss_i_3_7
post #3 of 30 (permalink) Old 10-28-2019, 01:24 PM
here's a couple of models..
Ray Newman likes this.
Stick486 is offline
post #4 of 30 (permalink) Old 10-28-2019, 04:35 PM Thread Starter
First Name: Steve
Room is not the real problem for me. I do understand the drawbacks. Honestly, I don't use either piece much.
IF I were to buy another table, it would be cast table.... I like iron. I just do not like alum for "machining tools) tables...
I understand the fence issue... I would have to put/ build a sacrificial fence onto the existing vega pro fence. Feeding right to left fits with the jessem guides. I see the point of working from the end of the saw. My stand is on rollers, I roll it under a shelf whenever not in use. So, I can't foresee that being a problem.. it might be... just cant figure it out now.
I also get the "build a table" route. I just do not want to do that. I would rather spend the few hours it takes actually doing what I see as a project. I know, building a table is a project. My mind just does not work like that. Plus, expense... a WELL designed and built stand alone cabinet would be way more than the 300 to 500 for a table/ fence.
post #5 of 30 (permalink) Old 10-28-2019, 05:35 PM
I've built very functional tables for as little as $10 by repurposing materials. An added advantage of building a table is that if you build it the same height as your saw or work bench it can be used in conjunction with those as an auxiliary. Time and cost depend on whether you just make a stand or you incorporate drawers, etc into it. I would have to guess that at least 50% of the forum opted to make one and that might be a low estimate. I would guess that those of us with more skill and experience would be closer to 90%. By making your own you get the features you like. My current table has drawers and probably is still under $300. I made my own insert plate out of some thick plastic sheet that my son brought home. I suspect it's acrylic. My Hitachi M12V2 adjusts from above the table and I let my insert plate float in the rabbet on the table which allows me to lift it out when I change bits which I find much easier than trying to do that in table.
Nickp likes this.
post #6 of 30 (permalink) Old 10-28-2019, 07:00 PM Thread Starter
First Name: Steve
ok. Let me phrase my question differently.
My router table is 2/3 complete. I still need to add drawers, racks, and wheel locks, paint, etc.
I also opted to include my grandfathers table saw into my router table. Here is a quick pic as I was headed out the door.
What do you think of insert plate vs plate with only router bit ring?
Name:	router table.jpg
post #7 of 30 (permalink) Old 10-29-2019, 10:16 AM
richjh's Avatar
First Name: Rich
I added the tablesaw extension from MLCS to my saw. I use the Triton router TRA001. I have a separate router table but use the saw setup more often. The extension has slots for the fence so I can add and remove it quickly. I can still cut narrower stock on the saw without removing the fence. I purchased the cast iron top but MLCS has other material options. I like having the insert plate myself and I don't mind reaching under the table to lock the router. I added a foot pedal switch for power so I only need to turn the power switch on the router off to raise and lock the router to change bits.
Basically, a tool is an object that enables you take advantage of the laws of physics and mechanics in such a way that you can seriously injure yourself - Dave Barry
richjh is offline
post #8 of 30 (permalink) Old 10-29-2019, 12:22 PM
Sorry Steve but I'm not sure what you mean by plate with ring only. Can you post a link to an example?
post #9 of 30 (permalink) Old 10-29-2019, 12:24 PM
Not on the subject but I could not help but notice the beautiful welds on the saw stand! WOW! Nice job.
senebraskaee is offline
post #10 of 30 (permalink) Old 10-29-2019, 12:32 PM
A couple of suggestions, if you are willing and have room to use the router from the END of the saw, not the front.
The simplist solution is to make a fence like the one pictured, that's long enough to be clamped to both sides of the router area. You may be able to buy a fence that's wide enough to span with a few inches to spare for the clamps. Normally you just adjust one end forward or back to set the fence accurately. Unlike the TS fence, the adjustments are made around a single point (the bit) so it is always parallel to the cut line. A TS fence has to hold a long piece parallel to a blade, so a T shaped fence base is required to make it parallel to the blade as you push the piece into the blade.
By having a separate fence, you may be able to make cuts on the saw without changing the router setup.
The other option is to make a wide saddle type add on fence that fits over and clamps to the TS fence. Something like what you'd make for a detachable tall fence. But you will find the minute adjustments you make on a router fence very hard to make accurately with the T type TS fence. Try nudging your TS fence by an exact 17/1000 ths, a gross adjustment for a router fence.
The attached drawings are for a fence you could clamp on if you make the base long enough. The picutes are some interesting ideas and how to hook up to your DC system.
Name:	router fence 3.jpg
Name:	router fence 2.jpg
jj777746 and wagspe208 like this.
