soft start/variable speed table setup - Router Forums
 19Likes
post #1 of 201 (permalink) Old 04-26-2009, 12:11 PM Thread Starter
TwoSkies57's Avatar
Default soft start/variable speed table setup
greetings all... here is my situation: I've built a custom router table, invested in top of the line accessories blah, blah, blah.. but as of yet, still have not purchased a router. I would idealy want to have remote control (outside of the router box portion of the cabinet) of router motor speed. Right now, the only production router i can find that allows for this is the Milwaukee 5625 sold as a package with remote varialble speed control. This package has reviewed very well and certainly isn't a bad consideration, however, I'd like to know of any other options. From what I've read, the big PC's and Milwaukee's with soft start and VS will not allow for a 'remote' motor speed controller. I've read through the forum and could not find anything that answered my questions, so i figure go straight to the experts..thanks in advance for any assistance...
TwoSkies57 is offline
post #2 of 201 (permalink) Old 04-26-2009, 03:16 PM
dutchman 46's Avatar
First Name: Howard
Welcome to Router Forums, I am not sure of any others that come with a remote speed,
and you taught me that one had it. One of the biggest questions are finding a good plate that will fit a particular router, or which router is the best for table, or hand held routing.
If anyone has an answer for you, they will post. Have If you will give us a little more about yourself, We will be able to communicate and hold common interest with you. Who knows, your friend may be a part of Router Forums
John 3:16
dutchman 46 is offline
post #3 of 201 (permalink) Old 04-26-2009, 05:21 PM
kolias's Avatar
First Name: Nicolas
Bill welcome to the forum,
perhaps you can tell us why the remote starter? I would like to learn.
Soon you will get an answer from the other members
Nicolas
kolias is offline
post #4 of 201 (permalink) Old 04-26-2009, 05:37 PM Thread Starter
TwoSkies57's Avatar
ok guys, here is the short story.. quite honestly, the table I've built is way beyond what I need. or probably will ever need for that matter. But dang, its cool. 27 x 49 x 1 3/8" tabletop with an Incra LS fence, wonderfence, Incra rails and mounting base (yes, attached to the router table for quick and easy relocation/removal of the fence) The cabinet itself is 41 x 27. The Cabinet mounts as an addition/extension to my cabinet saw. Will purchase a woodpecker PR2 lift as soon as I decide on the router. I already have a digital height readout mounted on the control side as well as a deadman switch. I've ordered a Jessem Mit-r-slide which I will adapt to my fence assemblies via machined aluminum stock if necessary. not to mention just way to many dooo dads and thingamabobs.. *L*.. You dont' even want the long version, trust me.. anyways, back to the question at hand.. I guess the answer is just cuz, easy access and control of router speed etc.
OH, did i mention, it just looks cool?
post #5 of 201 (permalink) Old 04-27-2009, 10:29 AM
CanuckGal's Avatar
First Name: Deb
It sure sounds cool. A picture would be great!
CanuckGal is offline
post #6 of 201 (permalink) Old 04-27-2009, 10:50 AM
HI Bill
It sounds like you are going over the deep end just a little bit,,you can pull the control device off the router and mount it in a remote box if you want to..
Or just buy a older router that doesn't come with a VS device built in and just pickup a remote device...(20 amp.type) it will not have the soft start but almost,but you can turn it off or on from the remote box control and control the speed from the remote box..the one that comes to mind is the 3 1/4hp PC.
post #7 of 201 (permalink) Old 04-27-2009, 03:31 PM
So, i am brand new to the Forum. I, too, want to know what router(s) would be best suited to use in a table. However, I am concerned with a couple of other things: how powerful a tool do I need (is a 2 -2 1/4 HP enough); can I get a tool that can be adjusted from the top surface of the table without using a special surface plate (I am reluctant to have to deal with leveling the plate and assuring that it is flush to the rest of the table top); is variable speed necessary; and, finally, what specific tool(s) do you all recommend? Thanks in advance.
selewis is offline
post #8 of 201 (permalink) Old 04-27-2009, 05:01 PM
First Name: gary
With all of those controls ----special fence, special lift-- what do you intend to do? If it is to make lots of joints, then it makes sense. For edge work, some of it might be excessive.
People on forums debate the advantages of a Shaper instead of a router. It sounds like your investment would currently match the cost of a shaper (including the tooling).
For my shop made router table, I bought a 2.15hp Milwaukee. No lift. Height adjustment is above the table. For Dados only, I use a Festool router and their MFT table -- this avoids the hazards of a Dado blade on a tablesaw. For joints, I use a WoodRat mounting a DeWalt 625.
My router investment for the table was $150. Period. Used only for edge work.
gary curtis
garycurtis is offline
post #9 of 201 (permalink) Old 04-27-2009, 05:08 PM
First Name: gary
Soft start offers an advantage primarily to hand-held routers. Not having it means that the machine will jump out of control every time you hit the on/off switch to the ON position. Variable speed keeps the cutting tips from going 'super-sonic'. Thus preventing overheating the carbide tip and burning the wood.
Also allows speed adjustments to match the wood hardness.
gary curtis
post #10 of 201 (permalink) Old 04-28-2009, 06:19 PM Thread Starter
TwoSkies57's Avatar
bobj3, I passed up 'a little over the deep end' on this thing long ago, but all in all, that was kind of the point of the project. waiting for great deals, waiting for sales, nickel and diming it as I went along. The research I've put in, the time, craftsmanship etc. have all contributed to a huge learning curve. Primarily with cabinet design and layout.
  LinkBacks (?)
LinkBack to this Thread: https://www.routerforums.com/table-mounted-routing/14019-soft-start-variable-speed-table-setup.html
Posted By For Type Date
Milwaukee 5625 conversion This thread Refback 03-22-2011 06:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
New router, need table, building dovetail cabinets santana157 General Routing 7 02-02-2009 11:34 PM
Fun way to test table saw setup rwyoung Show N' Tell 9 01-26-2009 05:44 AM
my new table idea tryingtokeepmyfingers Table-mounted Routing 9 09-29-2008 04:17 AM
help on new table and fence setup fasttruck860 Table-mounted Routing 19 03-23-2008 09:12 PM
Sold: Router Table or Table Top -Sam- Woodworking Classifieds 10 01-29-2005 09:15 PM
