dado grooves for raised panels - Router Forums
post #1 of 2 (permalink) Old 04-26-2009, 07:25 PM Thread Starter
First Name: joe
Default dado grooves for raised panels
How do people do the grooves that hold the raised panels in a 6 panel door.
I put a half inch wide dado so far.... they are only a quarter inch deep...is this enough? If I use a standard panel ogee bit on both sides of my panel blanks
.. what thickness
would I have to start with in order to have a shaved down edge that fits a half inch groove.?? Any info from door makers appreciated.
rout1111 is offline
post #2 of 2 (permalink) Old 04-26-2009, 07:51 PM
HI rout1111
Your making a easy job to hard,, just use a standard R & S set, or a T & G SET , it will do all the work for you..
2 pc 1/2" Shank Tongue & Groove Assembly Router Bit Set - eBay (item 130302357551 end time May-01-09 12:20:26 PDT)
2 pc 1/2" SH V-Joint Tongue and Groove Router bit Set - eBay (item 140315267894 end time May-18-09 19:36:39 PDT)
2pc 1/2" Shank Roman Ogee Rail & Stile Router Bit Set - eBay (item 140315929282 end time Apr-28-09 13:16:03 PDT)
.. what thickness
Is there quick fix for slightly loose fitting raised panels? tpyke General Routing 4 06-16-2010 07:12 PM
Dado Jig for Plunge Router bobj3 Jigs and Fixtures 35 01-22-2010 01:01 PM
Router for raised panels Jtomwoods Table-mounted Routing 5 11-03-2009 07:20 PM
Dado cuts in plywood BK9MJE Tools and Woodworking 4 04-18-2009 01:28 PM
Router Table Dado Jig RoyBullets Jigs and Fixtures 11 06-16-2008 08:41 PM
