Help for newbie please! - Router Forums
 11Likes
post #1 of 17 (permalink) Old 01-16-2020, 10:22 AM Thread Starter
Default Help for newbie please!
I am retired, living in the UK and disabled after serving in the London police.
I now want to get some knowledge under my belt using different equipment. I have a Bosch router, and appreciate different models to different countries, but I followed what my father in law did with his, but still cannot adjust the depth of the cut.
I really would appreciate real help and advice on making life easier and using the knowledge in forums
Name:	ROUTER SETUP.jpg
steve1958 is offline
post #2 of 17 (permalink) Old 01-16-2020, 10:50 AM
Not familiar with that router, but since it's a plunge model, it may have a spring to lift it when using it hand held. In most models, you must remove the spring to use it in a table. My thinking is that the spring might be interfering with the fine adjustment.
I hope that Harry from Australia checks in because he has a similar lift setup, uses Makita routers, and likely will have a good solution.
TenGees likes this.
post #3 of 17 (permalink) Old 01-16-2020, 10:59 AM
difalkner's Avatar
First Name: David
Welcome to the forum, Steve! Add your first name to your signature line to clear the N/a in the side panel. Add your location, as well.
It appears the depth stop block is engaging with the depth rod. Maybe this isn't what you're asking but it won't go any deeper with that engaged.
David
TenGees likes this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #4 of 17 (permalink) Old 01-16-2020, 11:47 AM
Contributor of the Month
PhilBa's Avatar
First Name: phil
That's an interesting lift mechanism. I wonder how solid it is. Seems like vibration might eventually move the scissor lift if it isn't screwed down. Though tension from the router may be sufficient to keep it in place.
And, good catch by David on the depth stop. Looks like a good candidate for the culprit. Springs could be an issue. Also is the plunge lock engaged?
difalkner, TenGees and RainMan 2.0 like this.
Visit my shop website.
PhilBa is online now
post #5 of 17 (permalink) Old 01-16-2020, 11:53 AM
roofner's Avatar
First Name: Gary
It appears not to be lifting straight top look's like an angle.
roofner is offline
post #6 of 17 (permalink) Old 01-16-2020, 12:10 PM
difalkner's Avatar
First Name: David
I straightened it for him...
David
Help for newbie please!-router-setup-depth-stop-block-engaged-straightened.jpg
TenGees, Nickp and RainMan 2.0 like this.
David
Romans 3:23
post #7 of 17 (permalink) Old 01-16-2020, 12:50 PM
PhilBa's Avatar
First Name: phil
I presumed the angled look of it was perspective distortion in the photo. It's pretty easy to take photo of something that is completely straight but looks way off kilter.
difalkner and Nickp like this.
post #8 of 17 (permalink) Old 01-16-2020, 12:56 PM
Hey, Steve; welcome!
Could you post some more info on the router model? It's not something we see over on this side of the pond.
DaninVan is online now
post #9 of 17 (permalink) Old 01-16-2020, 12:58 PM
RainMan 2.0's Avatar
Depends how close your camera lens is also . If you took that photo from 8’ away and then cropped it , there wouldn’t be much distortion.
Btw welcome to the forum Steve
difalkner likes this.
Ok ,I never insulate
RainMan 2.0 is online now
post #10 of 17 (permalink) Old 01-16-2020, 12:59 PM
