B&D Router 7613 will not mount on a Bosch RA1181 table - Router Forums
 1Likes
  • 1 Post By Bstrom
post #1 of 7 (permalink) Old 04-26-2020, 09:09 PM Thread Starter
Default B&D Router 7613 will not mount on a Bosch RA1181 table
I have a Black and Decker router Model 7613. It will not mount to my Bosch RA1181 router table. Any suggestions or fixes for this?
mschindler is offline
post #2 of 7 (permalink) Old 04-26-2020, 09:17 PM
welcome to the forums N/A...
is because of the hole pattern???
post #3 of 7 (permalink) Old 04-27-2020, 06:34 AM
Bstrom's Avatar
First Name: Brian
Welcome to the Greatest Router Circus on Earth! You’ll find it all right here...
Look online for the table manual and/or compatibility of your router with the table base plate. I kinda doubt there will be much Of a match, which means making your own holes. Or, move up to a router lift like the popular Jessem Rout-R-Lift II - it is compatible with many 3.5” diameter router motors. I really like mine and do several others here.
Stick486 likes this.
Common Man Woodworking
Powell, TN
Bstrom is offline
post #4 of 7 (permalink) Old 04-27-2020, 08:57 AM Thread Starter
Thank you for your time and info.
Mike S.
post #5 of 7 (permalink) Old 04-27-2020, 09:58 AM
First Name: Frank
BRIAN, Do you know if the lift you mentioned will fit a Bosch Table?
Thanks,
Tagwatts1
Tagwatts1 from Utah
Tagwatts1 is online now
post #6 of 7 (permalink) Old 04-27-2020, 10:58 AM
Bstrom's Avatar
First Name: Brian
Thanks,
Tagwatts1
I have the RA1181 Bosch table - you'll have to route 1/16" off each side of the Jessem's Rout-R-Lift II phenolic top to get it to fit. Not a problem unless that idea freaks you out. Not a biggie. I used the Bosch RA1181 leveling hardware and created the holes needed to fasten it down. Works beautifully!
Powell, TN
Bstrom is offline
post #7 of 7 (permalink) Old 04-28-2020, 11:04 AM Thread Starter
Mike S.
