T-Track Table location - Router Forums
 10Likes
  • 3 Post By Cherryville Chuck
  • 2 Post By Danman1957
  • 1 Post By Bstrom
  • 2 Post By RainMan 2.0
  • 2 Post By Marco
post #1 of 9 (permalink) Old 04-27-2020, 07:49 PM Thread Starter
Marco's Avatar
Default T-Track Table location
I am not sure where to put the T-Track location on the router table. What is the distance (center to center) from the T-Track to the center of the router plate? Miter Slot?
I put one on my first table (6") but since I didn't use the T-Track omitted it on my second RT. I plan on using it on the new table.
Galatians 5:13
Marco is offline
post #2 of 9 (permalink) Old 04-27-2020, 11:14 PM
If you want to use it for a feather board then it needs to be as close as possible to the insert plate as it will still be 3 or 4" at least to the center of the bit from the edge of the plate. For anything else I recommend using a push block along the fence instead. Simpler and works better.
Danman1957, TenGees and Stick486 like this.
post #3 of 9 (permalink) Old 04-28-2020, 08:34 AM
Danman1957's Avatar
I just finished my R/T and I used a miter track and no T slot track on the table. I can use a miter gauge or a feather board or a sled..., I did use 3 T slot tracks on the fence, 2 to hold the sliding fences right and left, and 1 at the top for feather boards. I will post pictures within the next day or so. It is from the New Yankee Workshop plans but slightly modified.
Cherryville Chuck and TenGees like this.
Don't fear your tools, pay attention and respect the tools and avoid injury.
Danman1957 is online now
post #4 of 9 (permalink) Old 04-28-2020, 07:29 PM Thread Starter
Marco's Avatar
Look forward to the pics.... how far did you place the miter track from the insert plate?
Galatians 5:13
Marco is offline
post #5 of 9 (permalink) Old 04-29-2020, 05:18 PM
Bstrom's Avatar
First Name: Brian
I’m using the miter slot that was cast into my Bosch RA1181 table and an adjustable featherboard In it on the table surface, and the two OEM feather boards on the fence - this really captures the piece and with a push stick removes any danger of flying wood! Cover 98% of all the cuts I make. It has been suggested that pieces which will be cut to a narrow dimension (stile/rails, etc.) be dado’d or grooved while still a larger workpiece and ripped to size thereafter.
Danman1957 likes this.
Common Man Woodworking
Powell, TN
Bstrom is offline
post #6 of 9 (permalink) Old 04-29-2020, 07:14 PM
Country: South Africa
First Name: Biagio
Charles, have you had any issues with the workpiece moving away from the fence, or being forced upwards “over” the bit with your pushblock method? Is it necessary to have some means of trapping the workpiece (sandpaper strip, toggle clamp, rabbet)?
Biagio is offline
post #7 of 9 (permalink) Old 04-29-2020, 08:38 PM
RainMan 2.0's Avatar
Jim I have no idea if this will be of any help , but I took a pic of my Incra table so you could see where they put the track
Danman1957 and Herb Stoops like this.
Ok ,I never insulate
RainMan 2.0 is offline
post #8 of 9 (permalink) Old 04-30-2020, 10:28 AM
Danman1957's Avatar
Jim,
I placed my miter track 1-1/2'' from the edge of the plate.
Dan
post #9 of 9 (permalink) Old 04-30-2020, 05:04 PM Thread Starter
Marco's Avatar
Thanks Rick and Dan
Danman1957 and RainMan 2.0 like this.
Galatians 5:13
Marco is offline
