collet wrenches for porter cable - Router Forums
 20Likes
post #1 of 25 (permalink) Old 05-25-2020, 08:18 PM Thread Starter
Charlie68's Avatar
First Name: Charlie
Default collet wrenches for porter cable
Moving forward with making my new router table. Got the Porter cable router motor today but the OEM collet wrenches that came with it are really poor quality. so I am looking for some replacements.
I know some of you really like the Muscle Chuck but there is no money in the budget for it. I have some open end wrenches that I use on my tractor but I would have to grind one of them down and that would weaken it for tractor use. Besides that they are fairly bulky for using on the router.
To get to my question: Rockler, Woodcraft, Peachtree and I am sure others all sell offset router wrenches. Those of you that have the offset wrenches, which brand do you prefer?
There are craftsmen and there are artists and then there are guys whose wife says “That looks nice dear but it doesn’t match anything in the house.”
Charlie
Charlie68 is offline
post #2 of 25 (permalink) Old 05-25-2020, 08:33 PM
kp91's Avatar
First Name: Doug
If it's the same collet as my 890 and 690 porter cables, it's a 1-1/8 wrench. You can find them at woodcraft and rocker, or look for low profile or thin head wrenches at the hardware store.
I have a full size combination wrench I have ground a little thinner, because the stamped wrenches slip on the arbor nut. The wider wrench is more comfortable to use
Charlie68 likes this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 25 (permalink) Old 05-25-2020, 09:13 PM
My router and plate just sit on the rabbet around the hole so that I can remove it to change bits. That eliminates the need for an offset wrench. Even though I switched to a Musclechuck I still take it out to loosen it. It’s just easier that way. That’s assuming you aren’t using a lift with that router.
post #4 of 25 (permalink) Old 05-26-2020, 07:41 AM
sreilly's Avatar
First Name: Steve
I know I bought a set for my Bosch 1617EVKS and just Googled for chuck wrenches for that router and got plenty of results. Choose from there.
sreilly is online now
post #5 of 25 (permalink) Old 05-26-2020, 07:52 AM
tappet wrench for the shaft..
TenGees and Charlie68 like this.
post #6 of 25 (permalink) Old 05-26-2020, 08:16 AM Thread Starter
Charlie68's Avatar
First Name: Charlie
Actually I am using a lift. I don't need the offset, I just need a better wrench. The PC 7518 is a hog to lift out of the table port. I have a set off Rockler offsets for my Bosch. They are okay, small and easy to use but the horror stories about the jaws screws falling into router motor concern me. I am going away from the Bosch so that concern is going too.
Growing up on the farm I thought I knew about most tools but have not heard of a tappet wrench. I will have to do an internet search on tappet wrenches.
Charlie
post #7 of 25 (permalink) Old 05-26-2020, 09:48 AM
roxanne562001's Avatar
First Name: Roxanne
Here is a set on Amazon that looks pretty good if you don't need them offset looks like good ratings .
https://www.amazon.com/Grip-Super-Th...0504263&sr=8-2
roxanne562001 is offline
post #8 of 25 (permalink) Old 05-26-2020, 09:54 AM
the stamped ones bend pretty easily w/ a little heat..
post #9 of 25 (permalink) Old 05-26-2020, 09:47 PM Thread Starter
Charlie68's Avatar
First Name: Charlie
Well it is like this. I really want to handle the wrench before I buy it. If it is stamped or 18 inches long like my tractor wrenches, I think I will deal with what I got. I live in the middle of ranch and farm land and apparently the locals have no need for tappet wrenches.
NAPA - never had heard of a tappet wrench
Oreilly's Auto parts -never had heard of a tappet wrench
Carquest- Sales person knew what they were but had never sold any and had no idea where to get one. Maybe Snap On tool he thought.
On line Menard's, Lowes, Home Depot, Northern Tool, and Harbor Freight either had nothing or over 2000 items to search thru if I searched "tappet wrench"
Using "thin wrench" got me better results so I will try the local Napa and Oreilly's tomorrow for "thin" wrenches. I am sure Snap On has them but they only do wholesale to local mechanics around here.
I guess if need be I should be able to grind down a crowfoot and use it with a short breaker bar.
Thanks every one for your efforts.
Charlie
post #10 of 25 (permalink) Old 05-26-2020, 10:44 PM
hard to believe
https://duckduckgo.com/?t=ffsb&q=tap...b=v96-1&ia=web
