help with dust collection - Router Forums
post #1 of 4 (permalink) Old 07-09-2009, 07:44 AM Thread Starter
Default help with dust collection
hey everyone i have built a table and need advice on running dust collection from my vacuum, i have installed a port on my fence but i would also like to use the port on the router (triton), my fence port is 2 1/2" and the router port is 1 1/4" i believe and my shop vac is a 2 1/2" inch hose, is there a fitting out there like that and does anyone have pictures of this setup?
uncleglenny is offline
post #2 of 4 (permalink) Old 07-09-2009, 08:43 AM
Talking
Morning, at least it is here.
I'm running into the same situation and I haven't got it set up yet.
My router dust collector is 1-1/4, Vac is 2-1/2 and fence is 2-1/4 or something. Doesn't fit the shop vac very well, still working that part out.
The idea I hit on and the direction I'm working is using about a 6" length of 3" thinwall PVC, capped at both ends and running the Vac to one end of it and the two dust ports outputs into holes drilled along the length, essentially making a manifold. The advantage being that, since I'm making the holes, I can make 'em any size I need depending on whats available. Also, as the hose to the router doesn't need to be that flexible and will help hold the manifold in place. I have a portable benchtop with foldup legs so haven't got a good place to anchor it. When I get around to building a cabinet for it I will incorporate the dust collection into the cabinet.
Good luck
John Schaben
jschaben is offline
post #3 of 4 (permalink) Old 07-09-2009, 09:05 AM Thread Starter
just to clarify my router port is 1 1/2 not 1 1/4.
post #4 of 4 (permalink) Old 07-09-2009, 09:56 AM
HI uncleglenny
Dust Collection Hose Adaptor
Dust Collection Question Tigerpaw Table-mounted Routing 17 04-16-2009 04:42 PM
Shop made dust collection? glintusa Tools and Woodworking 13 04-10-2009 05:47 PM
Dust collection base for pc 690 series routers rstermer Portable Routing 6 06-12-2008 08:42 AM
Table saw Dust Collection Guard angus Tools and Woodworking 13 03-20-2006 07:02 PM
Dust collection system for Router Table yhadar Lobby 2 12-31-2004 01:37 PM
