bosch 1619 evs lift - Router Forums
post #1 of 8 (permalink) Old 07-11-2009, 08:47 PM Thread Starter
Default bosch 1619 evs lift
Hi I am new to the world of routing.
I have a bosch 1619 router and have been making hardwood flooring with it.
I sure would like to get a lift kit for it but don't know which one to buy or which one will fit. any help would be great, I don't want to get one that would
not fit the router.
stephen800 is offline
post #2 of 8 (permalink) Old 07-12-2009, 12:11 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the RouterForums Stephen.
Dave
the "Doctor"
Dr.Zook is offline
post #3 of 8 (permalink) Old 07-12-2009, 03:19 AM
xplorx4's Avatar
First Name: Jerry
Greetings Stephen and welcome to the router forum.
Lamentations 3:22-23
xplorx4 is offline
post #4 of 8 (permalink) Old 07-12-2009, 04:39 AM
BigJimAK's Avatar
Stephen,
I do not have a 1617 but took a quick look and noticed that Wookpeckers Unilift fits your router. This is assuming that you want one with all the bells and whistles. With a plunge router you could get a universal plate from many sources and make your own. The largest disadvantage (that I know of) with these is that you have to reach under the table or lift the router out of the table to adjust the height. With the full lift you do not. Woodpeckers has a good reputation here. Here's the link to one solution.
Unilift Router Lift
Jim
BigJimAK is offline
post #5 of 8 (permalink) Old 07-12-2009, 06:12 AM
Jim, the router in question is a 1619 which is a whole different animal from the 1617.
post #6 of 8 (permalink) Old 07-24-2009, 11:09 AM
First Name: Eddie
I have a Bosch 1619 and find that it performs very well in a router table. No lift is necessary, since this router allows you to disable the springs (see the instruction book). With the springs disabled the router will slide up and down easily as long as the plunge control is held down. Releasing the plunge control locks the router approximately where you need it. Then fine adjustments are made using the big knob (this accessory comes with the router and extends the fine adjustment control) until the bit is exactly where you want it. When changing bits, slide the router all the way down and you will have plenty of room to get the bit and wrench in. The Bosch only uses one wrench. This router is not round and will not fit in any of the popular lifts.
Diamondman is offline
post #7 of 8 (permalink) Old 07-24-2009, 09:14 PM
Well stated Eddie.
post #8 of 8 (permalink) Old 07-25-2009, 02:12 AM
BigJimAK's Avatar
I stand corrected.
BigJimAK is offline
Bosch 1619 EVS Router Gloat GoonMan Table-mounted Routing 3 07-08-2013 08:59 PM
Bosch 1619 EVS sema08 Table-mounted Routing 14 07-08-2013 08:58 PM
Bosch 1617EVSPK or Bosch 1619EVS LBrandt Table-mounted Routing 25 01-19-2012 09:44 AM
bosch 1619 evs MaintenanceWorker General Routing 10 06-13-2009 01:02 AM
