changing bits from on top - Router Forums
post #1 of 4 (permalink) Old 07-15-2009, 08:58 PM Thread Starter
First Name: Dirk
Default changing bits from on top
Hi Ho: Thanks for the invite to introduce myself. I am pretty frugal (read that cheap) so sometimes I try to do things the hard way. I really like the Sommerfeld concept of having bits that match in height and mounting bits on a rubber grommet. I do have some concerns about the Triton router not being supported.
I want to try a Freud 3 1/4 hp router and wonder if I will be able to use a bent wrench to change bits from the top without raising the bit to the top. Has anyone tried this with the Freud router?
Thanks for providing this forum for exchange of ideas.
Dirk
dirko is offline
post #2 of 4 (permalink) Old 07-15-2009, 09:31 PM
Hi Dirk
I use the bent wrench all the time with my Freud 3 1/4 hp routers, you can get under the big panel bits easy to change them out
I also like the Sommerfeld concept and use his way most of the time.
Dirk
post #3 of 4 (permalink) Old 07-15-2009, 11:34 PM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the RouterForums Dirk.
Dave
the "Doctor"
Dr.Zook is offline
post #4 of 4 (permalink) Old 07-16-2009, 02:42 PM Thread Starter
First Name: Dirk
Hi Ho: Thanks Bob and Dave. I'm about to mount the Freud router and give it a go. I still like the Triton and wonder what will happen with them. Any news?
Dirk
dirko is offline
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 09:42 PM
Dealing with depth when changing bits uOpt Starting Off 6 01-05-2009 01:14 PM
Changing Bits lgkett New Member Introductions 3 12-11-2008 09:08 PM
Need help deciding on bits. ryan.s General Routing 8 03-25-2005 09:35 PM
