Pretend I am an idiot.... - Router Forums
post #1 of 9 (permalink) Old 07-29-2009, 06:01 PM Thread Starter
Default Pretend I am an idiot....
Not too hard to do by the way...
I would like a simple answer to a basic question.
I was impressed by BJ's dado jig and my question is....
What is the simplest way to route a 1" (or 40MM or whatever) slot in a piece of mdf 36x 8? And have a nice tight fit for the guide bushing.
James.
jw2170 is offline
post #2 of 9 (permalink) Old 07-29-2009, 06:51 PM
RustyW's Avatar
First Name: Rusty
James, I made mine with 2 pieces of laminate flooring. I used the intended guide as a spacer and then attached the ends.
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline
post #3 of 9 (permalink) Old 07-29-2009, 08:57 PM Thread Starter
See what I mean, I did not think of such a simple solution...
And they would already be trimmed to size.
I was looking at Laminate flooring for box panels as they come in so many timber patterns/colours.
jw2170 is offline
post #4 of 9 (permalink) Old 07-30-2009, 06:03 PM
dutchman 46's Avatar
First Name: Howard
James, Then, you would have to call a lot of us idiots. We tell everyone that there is no thing as a stupid question, We have all had our moments. So i say, If you have just made a note to yourself about this. You will not ever forget, and you will be a very smart person.!
John 3:16
dutchman 46 is offline
post #5 of 9 (permalink) Old 07-31-2009, 10:27 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Does this super simple way solve you problem James. Post #10
http://www.routerforums.com/table-mo...pped-slot.html
Harry
harrysin is offline
post #6 of 9 (permalink) Old 08-03-2009, 10:09 AM
Looks like this also might solve my problem of how to route a non-through, rounded-corner rectangle in a smallish piece. I don't see why I can't mount those side pieces wider than the router, and trace out a bigger rectangle, then route out the middle bits. I would think a core box for the perimeter followed by a straight bit for the middle.
Not trying to thread jack, but I can see how this would be useful for my pipe caddy (there's another thread on it somewhere).
-Andrew
adauria is offline
post #7 of 9 (permalink) Old 08-13-2009, 09:58 PM Thread Starter
Harry, BJ3,
Between the two of you, no question remains unanswered............
Sorry for the late reply, I was just going back through some old posts.
Yes, thanks - problem solved.
Looks like a camplate? and skis have been added to the rainy day list.
jw2170 is offline
post #8 of 9 (permalink) Old 08-14-2009, 09:25 AM
harrysin's Avatar
First Name: Harry
Originally Posted by jw2170 View Post
Harry, BJ3,
Considering once again what you wanted to achieve James, It dawned on me to remind you of the way that I make templates by gluing four pieces all ripped on the table saw and gluing them together, leaving an opening twice the offset wider than the slot or or groove you require. I'm sure that by now you can calculate offsets.
Harry
harrysin is offline
post #9 of 9 (permalink) Old 08-14-2009, 07:42 PM
First Name: Duane
I did something similar over the winter to a 30" wide piece of MDF.
What I did was clamp a board to the work piece to ride the edge of the router table.
Then moved it over as needed. Turned out pretty good that way as well I think. Mine went through on both ends though.
Duane867 is offline
Joke a Day bobj3 Lobby 4063 Yesterday 11:46 PM
Hi. And I'm an idiot, so trying to fix F&P problem... sbarron New Member Introductions 4 01-08-2009 02:14 AM
Iím such an idiot!! Nickbee Router Bits - Types and Usage 14 12-21-2008 09:16 AM
