help solving a routing problem - Router Forums
post #1 of 5 (permalink) Old 08-05-2009, 03:37 PM Thread Starter
Default help solving a routing problem
Hello to all, and once again thanks for allowing me the opportunity to join this router forum, my reason for joining is pretty selfish, I needed info on a routing process. I have a router and router table, with a fence....I want to make wooden flutes, and need to use a 7/8 core box bit to route a large bore down to halfs of a blank, they will be 3/4 x 2 1/4 x 24, and want help finding a safe way to secure the blanks for routing....I will need to step down to a depth, lift the piece move it about 3/4 of an inch and route another bore about 3 inches long, I don't feel comforable with my fingers in close to the bit, so I thought maybe someone had a jig idea I could use and try?.....hope all this makes sense.....Dennis
dtaylor is offline
post #2 of 5 (permalink) Old 08-05-2009, 04:19 PM
Hi Dennis
I'm not 100% this what you want to do
The easy to make hinge jig it may do the trick for you and I would suggest using the bits below to get it done.
You can also use a ski jig to do this job done
6 PC ELITE PLUNGE BALL GROOVING ROUTER BIT SET 1/2 SHK - eBay (item 380144702324 end time Aug-09-09 18:50:00 PDT)
Name:	hinge jig a.jpg
post #3 of 5 (permalink) Old 08-05-2009, 05:52 PM Thread Starter
Bob, thanks for the quick response...I want to 2 2 pieces of 3/4 x 2 1/4 x 17 in stock, and route a 7/8 bore...I would route 1 piece and then the 2nd one...then the 2 pieces are glued together and I will, with a little luck, turn a flute out of them.....but the bore is not all the way thru the stock, it runs from one end, about 12 inches or so, then there is a solid wood, and then another 7/8 bore that does not exit the other end, it is about 3 in long...so I have to route, lift move past the solid wood and then plunge down again, that kind of worries me.....Dennis
dtaylor is offline
post #4 of 5 (permalink) Old 08-05-2009, 07:22 PM
dutchman 46's Avatar
First Name: Howard
Hello Dennis, Welcome to the forum. I wouldn't call that selfish, You just need to get a job done. I believe that you will be back when you go into all the galleries, most of them have some information, and some have pages of valuable information. Enjoy!
John 3:16
dutchman 46 is offline
post #5 of 5 (permalink) Old 08-08-2009, 01:26 PM
Ghidrah's Avatar
First Name: Ronald
Here's my solution for a simple flute jig. The wooden slats match the spacing of the flutes, so you can make many to fit the diameter of any flute bit you have.
Mount the router on the ugly side, formica helps it slide easier and you're good to go
Ghidrah is offline
Routing Template Verlin Garrett Jigs and Fixtures 16 08-17-2019 09:12 PM
Routing with Template Tom template tom Guide Bushings and Templates 82 04-14-2009 02:25 AM
Routing Problem - Help! hikerbill General Routing 1 08-02-2008 10:40 PM
Acrylic routing problem marc.brunet.gagne General Routing 1 05-08-2008 01:04 PM
tambour grooves routing problem glencross Portable Routing 6 07-21-2006 12:56 AM
