Question: Big Jack vs. Router Lift: When to choose each? - Router Forums
post #1 of 1 (permalink) Old 08-07-2009, 03:45 AM Thread Starter
BigJimAK's Avatar
Default Question: Big Jack vs. Router Lift: When to choose each?
For those of you who have worked with both when would you choose the bit jack over the router lift? I understand that a bit jack is for plunge routers and lifts are generally for fixed-base routers, but assume you have both available.
I'm guessing that the bit jack would be better for table-based mortising and pin routing when you are hollowing out the center of an item, but beyond that?
BigJimAK is offline
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
router lift rravitsky Table-mounted Routing 1 05-24-2009 03:22 PM
Mounting router lift bobbyray Table-mounted Routing 4 01-30-2009 06:49 PM
Question about a router that just failed Johann George Tools and Woodworking 1 01-27-2009 11:01 AM
question regarding router settings Hitachi M12V cttdc General Routing 7 01-14-2009 08:10 AM
