incra - Router Forums
post #1 of 15 (permalink) Old 08-10-2009, 08:20 PM Thread Starter
First Name: Ron
Smile incra
Morning all, I`m waiting for delivery of my first Incra system for table saw and router table. From all reports I see I have finally done the right thing. Does anyone have any tips for a metric user who has progressed past the Imperial system 40 years ago in primary school. RonB
ronebooth is offline
post #2 of 15 (permalink) Old 08-10-2009, 09:58 PM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the RouterForums Ron, a fine family of woodworkers.
Dave
the "Doctor"
Dr.Zook is offline
post #3 of 15 (permalink) Old 08-11-2009, 06:01 AM
xplorx4's Avatar
First Name: Jerry
Greetings Ron and welcome to the router forum. I have heard only good reports about that system/
Lamentations 3:22-23
xplorx4 is offline
post #4 of 15 (permalink) Old 08-11-2009, 12:36 PM
HDS
First Name: Henry
Hi Ron,
I take it you're talking about an LS based system?
In which case I'm pretty sure you'll have to learn your fractions again!
Good luck with that,
Henry
HDS is offline
post #5 of 15 (permalink) Old 08-11-2009, 01:03 PM
Mike Wingate's Avatar
First Name: mike
Don't worry too much about the measurement scales. It is just a number. The precision joints are made following simple letter and number combinations. Buy the book with the 50 jig tapes if you are going to make routered joints. It is a truly terrific bit of kit.
Mike Wingate is offline
post #6 of 15 (permalink) Old 08-17-2009, 09:59 PM
First Name: Bob
Ronebooth,
Check your manual about ordering metric racks and scales. If you purchase the book with the tapes, you will probably have to put up with the Imperial system but this should not cause too many problems. For other work, you may be able to replace the standard racks and scales with metric versions.
I have an older Incra jig for the router and am well pleased with it. I think that you will enjoy yours also.
Bob
oak tech is offline
post #7 of 15 (permalink) Old 08-18-2009, 07:32 AM
Rutabagared's Avatar
First Name: Joe
Originally Posted by oak tech View Post
Ronebooth,
Bob
You can replace imperial racks and scales with metric. I looked into this a while back when I was considering converting my miter gauge 5000. The cost was minimal, less than $20 for materials, for seven racks and a scale. Some modifications were required to two of the racks (end rails required shortening) but it seemed straight forward. The scales are printed to a maximum of 80cm. This gentleman was very helpful.
Mark Mueller
Field Operations Manager
888.804.6272
[email protected]
Rutabagared is offline
post #8 of 15 (permalink) Old 08-20-2009, 07:17 AM
HDS
First Name: Henry
Hi Mark,
What about the leadscrew?
Surely, you had to replace that as well?
Personally I prefer imperial, fractions are so much easier on the human mind that the clinical offerings of decimalisation, don't you think?
Cheers,
Henry
HDS is offline
post #9 of 15 (permalink) Old 08-24-2009, 05:45 PM Thread Starter
First Name: Ron
Thanks boys, I have not received the gear yet but will let you know how I make out once it is installed. Ron (the muddler) Booth
post #10 of 15 (permalink) Old 10-16-2009, 08:14 PM
First Name: Gerry
Default Incra
Ron,
How are you doing with the Incra system? I'm looking into getting one for the RT I'm building.
Thanks,
G.L.
Gmex is offline
Incra Jig Process Imporovement tprofera Jigs and Fixtures 21 09-18-2012 08:45 PM
Dovetail jig or Incra system for table use? AlanZ Jigs and Fixtures 16 02-09-2011 11:28 AM
Incra LS Positioner and Bosch RA1181 table thistlefly Table-mounted Routing 3 01-05-2009 06:58 PM
Jointech Vs Incra Router Table fences KWD General Routing 2 10-24-2008 07:21 PM
Incra track/Featherboard tip LonePalm Tools and Woodworking 2 03-14-2008 07:30 PM
