enlarging the base plate of a 625 - Router Forums
post #1 of 7 (permalink) Old 08-14-2009, 11:25 AM Thread Starter
First Name: arlee
Smile enlarging the base plate of a 625
I have three dewalt 625 routers and decided to grind off some of the base of one of them just to accomodate large raised panel bits using different profiles.
I used spacer blocks and so forth,removed plunge springs and almost killed myself when the bit slid down and hit the base (before i ground it bigger).
Im still in one piece but my router had to go to the emegency room. thats when i decided to make the opening bigger. now i have a dedicated router for big bits and works great!! I was also lucky to have a friend who owns a manufacturing company give me a piece of phenolic 4 ft by 4ft for making base plates. I like to sneak up on my raised panels in 4 passes for making a nice tight fit on the panels.my question is does anyone have a good way to make a taller fence to attach to an oak park table? I am using mlcs router bits for making mitered cabinet doors. These bits are a little taller than normal.
or do i just glue a half dozen polypropelene 1 inch thick fences together..
has to be a neater set up....
thanks
went from a box of mistakes to a barrel now im up to a small buliding full,but
smile thinking of the fun i had trying.
redviper131 is offline
post #2 of 7 (permalink) Old 08-22-2009, 09:09 AM
dutchman 46's Avatar
First Name: Howard
Hi arlee, Are you trying to gut free hand, if so, you should use a bit in a router table. That in itself will possible lift the bit high enough to miss the router. When a bit that size hits something solid, it is going to feel like a bull ride. Be careful, when routing out part of the router base, your weakening the base! Stay safe.
John 3:16
dutchman 46 is offline
post #3 of 7 (permalink) Old 08-22-2009, 11:12 AM
Mike Wingate's Avatar
First Name: mike
The alloy base plate is very thin. Ridges and rims give strength. Take those away and you have a weakened base. If you go that route. Add a quality plastic (Bakelite) sub-base with an enlarged hole, bolted on , to beef up the base a bit.
Mike Wingate is offline
post #4 of 7 (permalink) Old 08-22-2009, 12:49 PM
HI arlee
It's to bad you took a grinder to the base, once gone it's gone ,it's true the OP base plate has that down fall,,can't take on the big bits,but so many other ways to get the job done,like buying bits that will fit the OP base plate hole or by making a simple jig to fit the top of the router table to let the bits spin free without hitting the mounting plate.. a simple 3/4" thick MDF board with a 4" hole in it will do the job nicely plus it's great way to make a high fence all at the same time and with a clamp or two it's set to make panels..with the big bits...
thanks
post #5 of 7 (permalink) Old 08-24-2009, 09:51 AM Thread Starter
First Name: arlee
Bobj3!! very good idea!! add the 5/8 MDF plus my higher fence all at the same time.. But now that I have thie base all filed out I will have to live with it..Just made some raised panels with it and liked the end result... Just goes to show ya sometimes your first idea may not always be the best idea to get the result your looking for.. Thanks
post #6 of 7 (permalink) Old 08-24-2009, 10:49 AM
Hi arlee
Your Welcome
You may also want to look at the bits below,they will work on the OP base plate easy and it a real safe and fast way to make them and they will work with the standard router table
Vertical Raised Panel Router Bits
MLCS Raised Panel Carbide Tipped Router Bits 2
http://www.routerforums.com/project-...th-worlds.html
post #7 of 7 (permalink) Old 07-25-2010, 05:04 PM
Phil P's Avatar
First Name: Phil
Take a look at the Trend T11 if you want a DW625 with a bigger opening. The T11 is made by DW for Trend but the baseplate is altered to accommodate 70mm (plunge) or 86mm (router table) cutters.
Phil P is offline
Triton Router Base Plate garbo.hunter Triton 10 08-09-2013 09:00 AM
Base Plate Help CanuckGal Portable Routing 47 05-16-2009 04:10 PM
base plate for mortising? How make it? help Bogydave Jigs and Fixtures 12 11-17-2008 02:15 PM
choosing a base plate ... reikimaster Table-mounted Routing 5 01-13-2006 10:37 PM
Centering Base Plate -Sam- General Routing 15 01-04-2005 10:15 AM
