Question for Bob and Rick (or anyone else?) - Router Forums
post #1 of 4 (permalink) Old 09-22-2004, 12:08 PM Thread Starter
Question Question for Bob and Rick (or anyone else?)
A friend of mine is in the process of building a router table, I was trying to explain some of the cool stuff that I saw on your show last week. How can he build the same type "pusher" (for sake of a better word) that you all have, I see it isn't like a T, it doesn't fit down in a slot, but looks as if it "glides" on the table. Where did you all find the neat little clamp type thing that holds the material to the "pusher". Also, I would like to know how to make the "anti-kickback" device that I saw you all using. I'm sorry my terminology is bad, but I am new to wordworking and haven't gotten the lingo yet.
Thanks!
Drew
dr00bie is offline
post #2 of 4 (permalink) Old 09-22-2004, 12:20 PM
The Router Guys
BobandRick's Avatar
This sounds like a miter gauge and toggle clamp. check out www.oak-park.com or just click at the top of the page under the sponsored by.
Thanks for joining,
Rick and Bob
The Router Guys
On January 17th, 2020 Dad passed Away at the age of 87 and I will miss him very much. If anyone is interested there is a memories website https://memories.routerworkshop.com/
BobandRick is offline
post #3 of 4 (permalink) Old 09-22-2004, 04:23 PM
kp91's Avatar
First Name: Doug
www.surpluscenter.com has a bunch of push and pull type clamps for making your own jigs
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #4 of 4 (permalink) Old 09-24-2004, 06:07 AM
Red face
The router equipment used on the router workshop is from Oak Park. How ever the same type of operation can be made up by using 1/4" phenolic over the router bit,
by drilling a hole in it and elongating it A second peice of phenolic can be used to make the "push guide"
by mounting a block on the edge at 90 degrees to the router bit. Then mount a hold down clamp onto the block to clamp your wood to the phenolic plate. the plate with the elongated hole can the be adjusted and clamped to the router table to position it to the router bit you may be using.
Richard Wey is offline
Bob & Rick This Box Is For You Bob N Show N' Tell 12 08-01-2007 06:11 PM
For Bob and Rick bobj3 Jigs and Fixtures 12 05-29-2007 05:38 PM
Question to Bob and Rick fibertech Jigs and Fixtures 0 04-20-2006 03:57 PM
Question for Rick fibertech Portable Routing 6 09-28-2005 12:58 PM
How many routers does Bob and Rick have. pmspirito Portable Routing 5 01-10-2005 08:58 PM
