My fence sucks! - Router Forums
post #1 of 11 (permalink) Old 08-17-2009, 10:33 AM Thread Starter
Mike Wingate's Avatar
First Name: mike
Default My fence sucks!
It really does. This hollow square fence grips the table just with suction from the vac extractor. It works well too.
Mike Wingate is offline
post #2 of 11 (permalink) Old 08-17-2009, 05:34 PM
First Name: Lance
Wow, that turned out nice!
Sawdust is not dirt
westend is offline
post #3 of 11 (permalink) Old 08-17-2009, 09:40 PM
xplorx4's Avatar
First Name: Jerry
If you would disconnect that pipe thing at the one end, it wouldn't suck so much!! Good job on the fence, I will need to redo mine some day but not today, it just isn't what I wanted it to be, all in good time.
Lamentations 3:22-23
xplorx4 is offline
post #4 of 11 (permalink) Old 08-18-2009, 02:01 AM
Thanks for sharing with us.
routertabledepot is offline
post #5 of 11 (permalink) Old 08-29-2009, 09:27 AM Thread Starter
First Name: mike
Polished and waxed. I got a set of near matching red featherboards. I made a template/jig to hold them. I don't have a T-slot in the table. I drilled 5 blind holes and glued in some punched rubber discs, to add a little grip in use.
post #6 of 11 (permalink) Old 09-07-2009, 12:25 AM
Gap_308's Avatar
First Name: Scott
Very cool idea!! Can we see the bottom of the fence? can we huh, can we
Thank You Veterans
Gap_308 is offline
post #7 of 11 (permalink) Old 09-07-2009, 11:22 AM Thread Starter
First Name: mike
I will post a pic later. It is just a semi circle cutout, that has a 45 degree bevel cut on the inside edge, to eliminate the step and encourage air flow.
post #8 of 11 (permalink) Old 09-07-2009, 11:48 AM Thread Starter
First Name: mike
2 pictures of the underside of the fence?
post #9 of 11 (permalink) Old 09-07-2009, 02:09 PM
Gap_308's Avatar
First Name: Scott
Default Im dense
Ok I only see the port at the bit, judging by its size ( fence ) it weighs alot. So are you saying the vaccum thru that center hole keeps the fence from moving. I thought you would have a series of holes running the entire length.
Thank You Veterans
Gap_308 is offline
post #10 of 11 (permalink) Old 09-07-2009, 03:37 PM Thread Starter
First Name: mike
Although the fence sticks to the table, it could pivot around the cutout. I have 3 clamps holding it to the table, as well as the suction. I would not trust suction alone on this. I have a Trend vacuum routing station that works. There was a TV program 2 weeks ago on the BBC. Where the presenter cobbled together a device that enabled him to climb a smooth aluminium clad building with 2 vacuum cleaner powered hand suction pads.
Face Lift for the Router Fence bobj3 Jigs and Fixtures 8 04-07-2013 09:21 AM
Some Thoughts on Fence Control Gilbear Table-mounted Routing 21 04-16-2010 05:38 PM
Which material for fence onap Table-mounted Routing 25 04-23-2009 06:23 AM
Pivoting fence arc vs distance? Bogydave Table-mounted Routing 16 01-14-2009 08:49 PM
