collett sticks to nut on Freud 2200 - Router Forums
post #1 of 4 (permalink) Old 08-26-2009, 05:24 PM Thread Starter
First Name: Dirk
Default collett sticks to nut on Freud 2200
Hi Ho: I appears that changing from 1/2 to 1/4 inch colletts is not an easy thing to do with the Freud 2200. There is a notch that makes the collett stick in the nut. I finally used 6 screwdrivers to compress the collett so it could be removed.
Is there a better way?
Dirk
dirko is offline
post #2 of 4 (permalink) Old 08-26-2009, 05:40 PM
Hamlin's Avatar
First Name: Ken
Hi Dirk,
It might be best if you contacted CharlesM. He's a fellow member here and works for Freud. I'm sure he can give you the help needed.
Ken
"A VETERAN"
Hamlin is offline
post #3 of 4 (permalink) Old 08-26-2009, 07:23 PM
xplorx4's Avatar
First Name: Jerry
With my Ridgid the nut and the collett are one unit. Each collett has a nut with it and you do not change the nuts back a forth.
Lamentations 3:22-23
xplorx4 is offline
post #4 of 4 (permalink) Old 08-26-2009, 07:33 PM Thread Starter
First Name: Dirk
Hi Ho: Now that makes sense. In this case a 1/4 inch collett was supplied without a nut. Maybe I'll have to just get another nut. Thanks for the info.
Dirk
dirko is offline
Red Freud., Black Freud "industrial" Drew Eckhardt Router Bits - Types and Usage 9 08-28-2015 08:02 PM
FREUD Dado Sets sawstop Tools and Woodworking 11 05-01-2010 01:00 PM
new member looking at Freud router feedback gettonna General Routing 9 02-22-2009 06:42 AM
Freud Router stjimm General Routing 1 01-03-2009 11:04 AM
Freud 2200 W norway New Member Introductions 3 05-01-2008 05:48 AM
