Router Cabinet and Dust collection - Router Forums
post #1 of 11 (permalink) Old 08-27-2009, 01:03 PM Thread Starter
Default Router Cabinet and Dust collection
I'm currently building a router cabinet and wanted to know what do I really need for dust collection. I've never had a cabinet before and wanted to know do I need both suction from under the cabinet and at the fence? What size port is ideal for the cabinet. Should the port go to the back of the cabinet or below the router? My master plan is to add a cyclone in the next year for my garage shop.
thanks,
tom
rolanddds is offline
post #2 of 11 (permalink) Old 08-27-2009, 01:25 PM
First Name: Michael
Default Router Dust cabinet
Tom,
You should definitely collect the dust from both the fence and the enclosed cabinet. I just finished my router table with a wye fitting that connects both hose lines to my dust collector. You can check it out in this thread:
http://www.routerforums.com/table-mo...completed.html
You will want a 4" port and hose from the cabinet and either a 2-1/2" or 4" port and hose from the fence. A 2-1/2" port for the fence is sufficient, IMO, and is less obtrusive on the top of the table. If you have a manufactured fence with an existing dust port, use the diameter that was provided.
Keep in mind, that when you build your cabinet, you will need air intake holes or a vent to draw the dust out the exhaust port to your dust collector. Also, it is important that the inside of the dust cabinet be as friction-free as possible. I used two coats of paste wax, buffed smooth. Other people have used melamine or smooth laminate for the inside. The less friction, the better the dust collection.
There are a lot of ideas, plans and photos of router table cabinets out there. Google it or check all the woodworking forums (including this one) for ideas on your build.
Good luck. Let us know when you finish it and post some photos!
thanks,
tom
Michael H is offline
post #3 of 11 (permalink) Old 08-27-2009, 02:17 PM
Cassandra's Avatar
First Name: Cassandra
Excellent, Michael! Very good point on the inside of the dust cabinet, which I hadn't considered. Many thanks!
Cassandra
Carpe diem, quam minimum credula postero
http://www.panoramio.com/user/5924351
Cassandra is offline
post #4 of 11 (permalink) Old 08-27-2009, 03:33 PM Thread Starter
Hey Michael,
Excellent posting full of all the information about my needs. You did a awesome job on your cabinet. It looks terrific. Where did you get your dust port for the cabinet from ?
tom
post #5 of 11 (permalink) Old 08-29-2009, 01:00 AM
First Name: Michael
Default Dust port for router cabinet
Tom,
Thanks for the compliment. The cabinet works really well for me.
As for the dust port fittings, the sources are in my post, but here it is again:
4" PVC elbow fitting, 4" Union connector and 4"- 2-1/2" wye fitting are from Peachtree Woodworking (Woodworking tools, supplies, plans, accessories and more - ptreeusa.com). They have most any plastic fitting you may need for dust collection. Woodcraft also sells a lot of plastic fittings.
The mount that holds the fittings to the back of the cabinet is actually a blastgate mounting bracket from Rockler (Woodworking Tools Supplies Hardware Plans Finishing - Rockler.com)
The 4" quick disconnect at the end is a FazLok female connector from Woodworker's Supply (www.woodworker).
Let me know when you finish your cabinet and post lots of photos.
Michael
Hey Michael,
tom
post #6 of 11 (permalink) Old 08-31-2009, 08:33 AM Thread Starter
What is the benefit of having a clear door? I've seen this on a few other posts? Did you ever determine if less holes would be satisfactory?
Thanks,
tom
post #7 of 11 (permalink) Old 09-05-2009, 08:15 PM
First Name: Michael
Default Router table dust collection
Tom,
Having a clear door panel is more of a preference than anything. I like to be able to see if the dust box is being cleared properly and will know if there is any blockage in the dust port without having to open the door. And I like the way it looks, that's all.
As for the holes, I've played around just a little. The four holes work just fine, but I think that three holes (1" to 1-1/4" diameter) would work just as well, maybe better. Since I have four, I'm not going to mess with the look and plug any of them, as the cabinet clears of dust nearly completely after each use (in conjunction with the fence dust collection port).
Best regards,
Michael
Thanks,
tom
post #8 of 11 (permalink) Old 09-07-2009, 05:54 AM Thread Starter
Ok Mike, that makes sense as far as air flow. Are you still happy with the magnetic catches versus just putting hinges on?
Thanks,
Tom
post #9 of 11 (permalink) Old 09-07-2009, 07:16 AM
First Name: Michael
Default Router table dust cabinet
Tom,
Yeah, I like the magnetic catches for the dust door. Just a personal preference.
post #10 of 11 (permalink) Old 09-07-2009, 10:23 PM Thread Starter
Great, thanks for all your advice. I'll definitely get some pics up when I am further along.
Tom
Router Table Completed - Finally! Rutabagared Show N' Tell 12 08-01-2011 09:22 AM
Dust Collection Question Tigerpaw Table-mounted Routing 17 04-16-2009 04:42 PM
Sold: Router Cabinet 150.00 dovetail_65 Woodworking Classifieds 2 11-18-2008 10:19 PM
Dust collection for router table Mike in Wilson Table-mounted Routing 2 05-06-2005 12:52 PM
