Problems with height adjustment Delta Router - Router Forums
post #1 of 6 (permalink) Old 09-03-2009, 11:54 AM Thread Starter
Default Problems with height adjustment Delta Router
HI, I am having problems getting my Delta Router/Shaper (table router) to move up and down. I haven't used it for a while and it seems to be "frozen". I live in a salt water environment and think that might have something to do with it. I have applied WD-40 to every moving surface, but it still binds when I try to move the router. Any suggestions out there?? Thanks.
hollypoint is offline
post #2 of 6 (permalink) Old 09-03-2009, 01:30 PM
hi hollypoint
Put the WD-40 back into the tool box and pickup some dry Teflon lube, DuPont makes some great stuff that comes in a small bottle but if you have some router bit lube it works great also, it's about the same stuff..just a bit higher in price.
Just a note ,,,,WD-40 is a great saw dust magnet ,,DuPont, milk white the norm
post #3 of 6 (permalink) Old 09-03-2009, 02:16 PM
xplorx4's Avatar
First Name: Jerry
Greetings (your name here) and welcome to the router forum.
Lamentations 3:22-23
xplorx4 is offline
post #4 of 6 (permalink) Old 09-07-2009, 06:55 PM Thread Starter
Default Wd-40
hi hollypoint
Hey Bob, Thanks . I will avoid the WD 40. Thank you so much for telling me that.
Janis
post #5 of 6 (permalink) Old 09-08-2009, 09:28 AM
Janis, do not feel bad about your choice of WD-40. It is the right product for trying to unstick your mechanism since it cleans and lubricates. Once you loosen up the lift you can wipe the threads as dry as possible and switch to a dry lube product.
I sold my Delta router/shaper a while ago so this is from memory. Remove the round fill plate and check carefully with a small mirror to be sure nothing has fallen in and is blocking the motion. (always use the vacuum hose to prevent build up in the cabinet)
Are your adjustment threads rusty? If so spray them with PB Blaster to remove the rust. Most often it is simply a build up of sawdust in the threads, and an air hose is the easiest way to remove that. What area do you live in? This is how we direct you to assistance when needed.
post #6 of 6 (permalink) Old 09-14-2009, 04:25 PM Thread Starter
Thanks, Mike. I am in Onancock, Virginia.
Janis
Building a New Router Table-What's the Ideal Working Height? gerrym526 Table-mounted Routing 12 07-19-2014 08:49 PM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
Craftsman 17543 Combo Fixed Base Height Adjustment Gator95 General Routing 14 11-29-2008 03:30 PM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 01:08 PM
