My RT build - Router Forums
post #1 of 11 (permalink) Old 09-09-2009, 05:33 PM Thread Starter
First Name: Tony
Default My RT build
Hi all,
I'm just finishing my RT using my Jet TS.
I decided using this system to save space in the shed.
I've used lots of ideas from you guys which I'd to say 'thanks'
I'm still working on the dust extraction system using my 'shop vac'.
The insert I made from scrap 4mm marine aluminium, the levellings sytem is four wood screws set into the corners (works a treat - thanks Tom for a great idea)
Table is faced both sides with 'Laminex', a hard plastic covering.
Last pic is my other hobby!!
Cheers all
Tony in NSW, Australia
hardwoodjoint is offline
post #2 of 11 (permalink) Old 09-09-2009, 07:01 PM
Bob N's Avatar
First Name: Bob
Hi Tony,
What a great job on the RT, looks like you did everything right and nothng at all wrong. Excellent work!
Now about that "other" hobby, tell us more about that rod if you will
Bob N is offline
post #3 of 11 (permalink) Old 09-09-2009, 07:51 PM Thread Starter
First Name: Tony
Thanks Bob,
As I said I just copied other peoples ideas.
The car is what we call a clubman or 'clubbie', it's based on the sports car designed by Colin Chapman, the Lotus 7.
This car is a homebuild from a plan, there are loads of other makes and models; Caterham, Westfield, Birkin and PRB.
This car is made from square section steel tube, the panels are professionally made fibreglass that bolt onto the chassis.
The rear axle is from an English Ford Escort model.
The engine is a Mazda 323, twin cam, 1.8Litre with an after market engine computer thats tuned by using a program on my laptop.
And yes, it does go fast, very fast. Enough to 'shred' a driving licence in one go!!
Cheers
Tony
Name:	Wanna buy a cat.jpg
post #4 of 11 (permalink) Old 09-09-2009, 08:00 PM
Bob N's Avatar
First Name: Bob
That is one sweet looking ride Tony! It has "speed" and "class" written all over it. I can see where it would be easy to fall into that hobby and spend more $ than the wife would allow me to get away with
Thanks for taking the time to share the additional info.
Bob N is offline
post #5 of 11 (permalink) Old 09-10-2009, 12:21 AM
CanuckGal's Avatar
First Name: Deb
Yep that is one "HOT" Rod. Nice!
I measured, I marked, I cut.
CanuckGal is offline
post #6 of 11 (permalink) Old 09-10-2009, 01:19 AM
xplorx4's Avatar
First Name: Jerry
Nice Car errr---Rod??? Yes nice Rod
Lamentations 3:22-23
xplorx4 is offline
post #7 of 11 (permalink) Old 09-10-2009, 06:41 AM
dustmaker's Avatar
First Name: Frank
Poor Router Table is getting neglected next to that cool rod. Congrats on both!
- Frank
Woodworking is more than a hobby.
It is a journey of discovery,
An application of innovation and creativity,
And an opportunity at self improvement.
dustmaker is offline
post #8 of 11 (permalink) Old 09-10-2009, 06:46 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
A mate had one with a Triumph 2.5PI engine, ZF limited slip and a ZF box. If the traffic lights went against you, you had to switch off as the rad was too small to cope if the car wasn't moving. You could do wheelies with it. Poor devil has dementia now and doesn't recognise his own family. He used to race great motors. The Cooper 1275S with the Shorrocks blower was terrifying!
Happy days!
istracpsboss is offline
post #9 of 11 (permalink) Old 09-10-2009, 07:50 AM
dustmaker's Avatar
First Name: Frank
Also meant to add, I used to own a Mazda 323 with 1.8L engine. Even unmodified that little car had some getup and go! With a light frame and your mods, it must be a sweet ride!
- Frank
post #10 of 11 (permalink) Old 09-11-2009, 11:24 PM
RustyW's Avatar
First Name: Rusty
Thats a good looking table Tony. Are you going to make reducer rings for that plate? Looks like it would be easy to attach them to the tabs on the router, if your leaving them in place.
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline
Build your own CNC cdndave CNC Routing 9 08-30-2010 11:20 PM
New Build cdndave CNC Routing 6 05-04-2009 05:45 PM
Drum build part1 of 2 Check twice! Show N' Tell 14 08-27-2008 02:45 PM
Want To Build A Router Table kjones2073 Table-mounted Routing 1 07-11-2008 11:50 PM
To Buy or Build gaviaimmer Table-mounted Routing 12 12-12-2004 08:00 AM
