round over problem - Router Forums
post #1 of 7 (permalink) Old 09-17-2009, 12:28 PM Thread Starter
Default round over problem
when rounding over boards, i find that i am leaving a ridge between each side that has been rounded over.
do i raise the bit or lower it?
woodwerx is offline
post #2 of 7 (permalink) Old 09-17-2009, 12:47 PM
Hi Peter
Use a bigger round over bit
http://cgi.ebay.com/1pc-1-2-SH-1-Rad...4.c0.m14.l1262
post #3 of 7 (permalink) Old 09-17-2009, 01:54 PM
BigJimAK's Avatar
Peter,
If the two rounded corners aren't coming together to make a continuous bullnose, you need to cut more wood. Therefore the bit must extend farther from the base. BJ may be right though. If the bit is too small you will begin to cut reliefs on the sides.
BigJimAK is offline
post #4 of 7 (permalink) Old 09-17-2009, 05:04 PM Thread Starter
thanks guys...will buy a bigger bit!!!!
woodwerx is offline
post #5 of 7 (permalink) Old 09-18-2009, 01:44 AM
First, I assume you are doing this with a handheld router.
If the roundover is too big for the wood, (especially when rounding over both sides) the bearing can ride on the previoiusly rounded over portion and actually cut too deep during the pass on the opposite side and produce a ridge along the edge. If you use a router table and fence to control the depth, you can eliminate that ridge. Set the fence so that it is flush with the bearing and use bit height to control the amount of roundover.
Tom Hintz, Publisher
NewWoodworker.com
Tom Hintz is offline
post #6 of 7 (permalink) Old 09-18-2009, 04:52 AM
allthunbs's Avatar
First Name: Ron
I'll add to Tom's comment. Rather than take the whole cut at once, reduce your depth of cut and do a few small cuts. They will be cleaner and you can control your round-over much more easily thus preventing the problem you're having.
That's one of the problems with routers. There's a variety of ways to address a problem. Not one is particularly better than the other, just a different approach to the same problem.
My first take would be use a router table and fence with feather boards. Failing that, I'd use shiis with an edge-treatment bit, if your workpiece is wide enough. If not, I'd use a foot.
Allthunbs
allthunbs is offline
post #7 of 7 (permalink) Old 09-22-2009, 08:49 PM
If you have a ledge on both edges of the roundover, then you most likely have two problems - the bearing is too small and you have the bit adjusted to take too deep a pass. Some roundover bits can also be used to create beads on one or both sides of the roundover - this is what you are doing. If you are using the router as handheld and have a bead at the edge of the board on which the router is resting, you have the bit set too deep; if you leave a bead at the bottom of the roundover, the bearing is too small.
You can purchase bearings from nearly all sources from which you purchase bits. If you have a caliper, measure the diameter of the bearing and go to the website for the manufacturer of the router bit that you are using. That should get you into the ballpark of the size bearing you need.
Jim
jimcrockett is offline
Bearing Bit Problem rstermer Router Bits - Types and Usage 7 06-12-2009 10:08 AM
Another new guy, another problem! Billyt New Member Introductions 8 03-22-2009 12:14 AM
Problem with my Hitachi M12V Visteonguy Table-mounted Routing 23 08-18-2005 11:22 PM
Hitachi M12V Router Problem dcarriere Tools and Woodworking 3 12-28-2004 06:50 AM
Round over on thin curved pieces Ken Massingale Table-mounted Routing 8 09-20-2004 05:36 AM
