Shank position - Router Forums
post #1 of 17 (permalink) Old 09-23-2009, 03:15 PM Thread Starter
Wizard1500's Avatar
First Name: Carl
Default Shank position
I received my Bosch 1617 router, and my table top from OP. I made the base, but still have to build the cabinet. I chucked up a 1/4" straight bit to try some box joints with the OP box joint jig. I was using some 3/8" scrap wood and the only way I could get the bit high enough was was actually raise the bit in the collet....so my question is, how far should the top of the shank stick out from the collet....thanks for your responses.....
Wizard1500 is offline
post #2 of 17 (permalink) Old 09-23-2009, 06:50 PM
Twill57's Avatar
Not sure if this is the answer you are looking for but, I place 2 O rings, in the bottom of the collet and set the bit to them. You want as much of the shank in the collet as you can, without bottoming out the shank or seating the cutting portion of the bit to the collet. You might want to check your set up. I would think that it should be no problem to get the full cutting length of a strait bit above the table. I know I can with my Hitachi and PCs.
Twill57 is offline
post #3 of 17 (permalink) Old 09-23-2009, 07:07 PM
Hi Carl
Here's a easy way,, pull the collet nut off the router, then put the router bit in the collet,,it should fit flush with the bottom of the collet...now put in back on the router it should be just right,,,you can buy longer bits, not all router bits are made the same way..
This is a trick from Bob R. of the RWS,,you will see him do it all the time on the show.
post #4 of 17 (permalink) Old 09-24-2009, 03:01 AM
Mike Wingate's Avatar
First Name: mike
Some router bits have a maximum extension line marked on the shaft to indicate how far out the bit can be.
Mike Wingate is offline
post #5 of 17 (permalink) Old 09-24-2009, 03:36 AM
xplorx4's Avatar
First Name: Jerry
Did not know that, I shall do that today to see how I have been doing at setting the bits. Thanks BJ
Hi Carl
Lamentations 3:22-23
xplorx4 is offline
post #6 of 17 (permalink) Old 09-24-2009, 05:29 AM Thread Starter
Wizard1500's Avatar
First Name: Carl
Thanks for the responses.....will give it another try, today.....
post #7 of 17 (permalink) Old 09-24-2009, 08:51 PM
Talking
Hi Carl
Read this last nite so thought I would try that today. The collets on both my Freud and Hitachi are to loose to let me get the thing back in the router. I did look to see how far out it is when the bottom of the shank is even with the bottom of the collett. The thing is out nearly an inch!!
I think I will keep doing it the way I have been. I do feel a lot safer now when I do have to pull the bit up some though.
John Schaben
jschaben is offline
post #8 of 17 (permalink) Old 09-24-2009, 09:03 PM
Hi John
I do it the way below 95% of the time
post #9 of 17 (permalink) Old 09-24-2009, 09:49 PM
Talking
Hi John
Hi Bob. This is what I was looking at with the bottom of the bit even with the bottom of the collett.
Haven't needed all that much depth of cut anyway so I decided not to try it. That is a pretty good size bit also. I suspect a 1/4" shank bit wont stand up so far.
John Schaben
jschaben is offline
post #10 of 17 (permalink) Old 09-24-2009, 11:57 PM
Hi John
Many of the router bits are made as Match Set,that's when the rubber grommet comes in to play, you don't need to move the router up or down when you switch out the bits in the sets,, the same thing is true with router bits if you have a lift kit on your router, most have a dial on them that can be used to get it right back to the same place when you change the bits out..but it real had to do that if you don't put the rubber grommet in place or use the collet nut as a gage by putting the router bit all the way down to the bottom of the nut..
Using 1/2" shank bits in 1/4" routers? baronr Router Bits - Types and Usage 14 12-28-2013 10:58 PM
1/2 or 1/4" shank for beginner bill0199 Router Bits - Types and Usage 9 06-21-2009 10:44 AM
shank depth pemdas86 Router Bits - Types and Usage 5 02-12-2009 01:55 PM
1/4" shank vs 1/2" shank Robbie Starting Off 5 01-06-2009 06:51 PM
3/4" Radius roundover bit with 1/4" shank chrisogrady Router Bits - Types and Usage 8 04-01-2005 08:08 PM
