Base plate opening - Router Forums
post #1 of 21 (permalink) Old 09-26-2009, 05:22 PM Thread Starter
First Name: bob
Default Base plate opening
I am new to this forum and also to woodworking in general. My problem today is the base plate opening for the router table I have made. After spending many hours on the table, it seems that I have made the base plate opening too big all around ( width, length, and depth. ) causing vibration, noise, and poor cuts. the table is mdf. Any suggestions as to how to fix this ?
drbbob is offline
post #2 of 21 (permalink) Old 09-26-2009, 05:36 PM
Hi Bob
By how much ? and how deep..?)
post #3 of 21 (permalink) Old 09-26-2009, 06:04 PM
Bob N's Avatar
First Name: Bob
Welcome to the forum Bob.
Bob N is offline
post #4 of 21 (permalink) Old 09-27-2009, 01:24 AM
Mike Wingate's Avatar
First Name: mike
Could you make a couple of 8mm thick discs, with different sized holes to suit your bits. Rebate your present opening to 8mm depth, and slip in a disc to fill the space.
Mike Wingate is offline
post #5 of 21 (permalink) Old 09-27-2009, 01:38 AM
TWheels's Avatar
First, welcome to the forum. I am sure you will find it a place of great friendlieness with many more experienced members eageer to share their knowledge and experience, and where all learn from each other.
You will also find beneath the surface a long-standing discussion of metric vs. imperial mesurments.
At this point I have nothing to offer to help you other than to suggest that you get to our ten post count quickly so you can attach a picture of what is your situation.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #6 of 21 (permalink) Old 09-27-2009, 03:13 AM
Country: Malta
First Name: David
Could you glue thin wood fillets into the recess and re-rout?
davcefai is offline
post #7 of 21 (permalink) Old 09-27-2009, 06:37 AM
allthunbs's Avatar
First Name: Ron
Hi Bob:
You haven't said what baseplate you have and a picture of the table to date would be good too. I've screwed up at least 4 table tops and used them until I got up the gumption to try again. I now build my table bases to accept exchangable tops.
Here's the scoop...
If you're not using an OakPark baseplate, it is possible that changing baseplates and recutting the recess to suit the OakPark baseplate would solve the problem. The OakPark tops are 11"x11".
My problem is that I use multiple baseplates in the same holes and none are the exact same thickness. There are several "kludges" that might help. I cut my insert very carefully using the OakPark method. This means that I have some confidence in how deep the flange is. To "adjust" from one baseplate to the other, I use the thinest, cheapest masking tape so "shim" up the baseplate. The masking tape can be continued up and part way across the edge of the baseplate to "fill in" that bit of excess.
An alternative is to put gussets across the four corners and set screws into the gussets so the heads become the bearing point.
Then, there's the "fancy" solution where you insert a thin wedge of some contrasting material around your baseplate, smooth it off so it's flush with the top of the baseplate and call the solution "marquetry."
The ideal solution would be to cut a new table top, this time using the OakPark method and shiis.
Just a collection of ideas that may help.
Allthunbs
allthunbs is offline
post #8 of 21 (permalink) Old 09-27-2009, 07:50 AM Thread Starter
First Name: bob
Thank you all for the welcome. The opening depth varies from 1/64 to 1/16 in. over spec. ( I must have tipped the router when making the cut. I am terrible at hand routing.) The perimiter is pretty consistant at 1/32 in. too large. the base plate is phenolic from woodpeckers. and all adjusting screws are maxed out. there is no picture. I have no camera.
drbbob is offline
post #9 of 21 (permalink) Old 09-27-2009, 09:48 AM
Hi Bob
That's not to bad, I would say just let it be, many ways to fix this error Longer screws would fix it to get it flat with the top, two small steel dowel (1/8" x 5/8" from Ace Hardware) in two corners to lock it in place so you can pull it or drop it in place easy...
Set it in place,drill the holes for the dowel pins,tap them in place then adjust the longer screws to get flat,adjust the longer screws from the under side with some blue stuff they use for gasket making to hold the screws from backing out..the blue stuff will let you tweak the screws just that little bit you may need..and yes the wood will hold the threads for the Allen set screws..
Wood working the art of fixing errors ..
post #10 of 21 (permalink) Old 09-27-2009, 05:31 PM Thread Starter
First Name: bob
Hey Ron-- thanks for the info. I kind of like the "marquetry" idea, but I'm not confident that I could locate the tremplate accuratly the second time. I should think about this for a day or two.
drbbob is offline
Where can I find this Slick method for cutting router plate opening into table Peter Sanders Table-mounted Routing 25 10-17-2015 01:57 PM
Triton Router Base Plate garbo.hunter Triton 10 08-09-2013 09:00 AM
Router Plate Installation Rutabagared Project Plans and How To 11 01-14-2012 07:15 PM
choosing a base plate ... reikimaster Table-mounted Routing 5 01-13-2006 10:37 PM
Centering Base Plate -Sam- General Routing 15 01-04-2005 10:15 AM
