Problems with Dewalt DW625 - Router Forums
post #1 of 10 (permalink) Old 10-02-2009, 05:30 PM Thread Starter
Default Problems with Dewalt DW625
Hello everyone, buy a new router dewalt DW625 drive you to validate the warranty because it did ring up top (not perform its function, that is not kept in place, as if swept), and the seller I said this is not recommended for use in a router table because the engine is filled with powder and burned, I have two questions to someone else the same thing happened with the thumb well? and it is true what he told me the seller? of course I thank you in advance
If the woman is a good thing, why God didn´t have one ?
pacodelrio is offline
post #2 of 10 (permalink) Old 10-02-2009, 05:51 PM
Question
Hi pacodelrio, sorry to hear you are having trouble.
I guess I'm not sure just what happened. The salesman(person) told you it was not to be used in a table? It fell out of the table?
I'm sure others have mounted them in tables.
John Schaben
jschaben is offline
post #3 of 10 (permalink) Old 10-02-2009, 07:16 PM Thread Starter
Traducción: español » inglés
Hi, thanks for your concern, it fell off the table this was a talk I had with the seller, I would comment that the router table, so the problem of regulating the depth ring (thumb well in the instruction) has a small ring mechanism that releases the bolt which is due to hold, it uses the same form as the depth lever that almost all routers have, well if you leave the ring in a sliding position by the force of the Springs router, this should not be quite the contrary I'll try and upload photos, showing the ring to which I refer, you receive a greeting from me
post #4 of 10 (permalink) Old 10-02-2009, 07:23 PM Thread Starter
sorry for my english ,the router never fell off the some table,
post #5 of 10 (permalink) Old 10-02-2009, 07:35 PM
Talking
Don't apologize for your english, you will never see me attempt spanish
We can work through the language stuff and try to help you.
I think I understand that to be a plunge router, yes?
If so, you could try removing the springs that help lift it when using it as a plunge. Somehow I think it should hold with springs in or out. Should be some type of depth lock device that you can adjust. Both my Hitachi and Freud use a lever and the tension on that is adjustable. My Craftsman uses a little more crude approach which is just a knob that clamps the base to the body.
Hope this helps.
John Schaben
jschaben is offline
post #6 of 10 (permalink) Old 10-11-2009, 10:42 AM
Mike Wingate's Avatar
First Name: mike
I am sorry to hear of your problems. I have a DW625 router in a table. The collet does get hot, but no other problems so far.
Mike Wingate is offline
post #7 of 10 (permalink) Old 10-13-2009, 07:49 PM Thread Starter
friends thanks for your interest, what happened was that I bought the router in a neighborhood where they sell much cheaper, I think that they are items that failed the quality control (this is called the outlet) but I took it to the authorized dealer and he respected the guaranty and he gave me another new unit, again thank you for your interest and keep in touch
post #8 of 10 (permalink) Old 10-13-2009, 08:01 PM
Bob N's Avatar
First Name: Bob
Glad to know that you have your problem resolved. The Dewalt 625 has a great track record both in and out of the table.
Bob N is offline
post #9 of 10 (permalink) Old 10-13-2009, 08:58 PM
drasbell's Avatar
found this post a few years ago..
Originally Posted by Greg_R
I have been using a Dewalt 625 w. a plunge bar for handheld use (used with a jig for making shelf pin holes) & for use on my Woodrat. Unfortunately, I have been having some issues with the unit:
1) The plunge stop nut (that keeps the router from returning to it's full height during plunge operations) does not actually stop anything and releases at random times. I'm not talking about the plunge lock... I'm talking about the quick release nut on the threaded rod (left side of the router). Is this a common issue? Should I get the nut replaced or should I get something from the hardware store that will fit (w/o the quick release "feature").
2) The knob that locks the depth stop adjustment is very tight and the metal foot inside the track can become twisted. (metal foot is what presses against the rack and pinion depth stop mechanism). The knob does not unscrew all the way (to lubricate or investigate further). Is there something wrong with this mechanism (i.e. go to Dewalt service center) or is this just bad design?
Finally, is there any way to attach a shop vac hose to the Dewalt 625 for hand held routing (aftermarket or shop made vac hose attachment)?
Thanks!
Life: Is a runaway train you cant wait to get on.
drasbell is offline
post #10 of 10 (permalink) Old 10-15-2009, 12:10 AM Thread Starter
Hi DRASBELL , I think the problem of nut design is still weak and ineffective, force is too much that has to contain, may cause accidents, hit me hard in my right hand, I would choose to change the nut by a common, if the problem recurs, luck and keep in touch
Problem mounting Dewalt Router to Caftsman Table Saw apollo2000 General Routing 15 01-26-2015 02:30 AM
Problems, problems, problems nikki1492 General Routing 7 07-21-2009 08:50 AM
Dewalt 3 base router rebate herbfellows Lobby 2 02-15-2008 12:29 AM
DeWalt DW618PK or Porter-Cable 893PK? LBrandt Table-mounted Routing 6 05-14-2006 07:31 PM
Dewalt DW625 FineHomesCarpentry General Routing 4 10-30-2004 02:48 PM
