Plans for Building a Routing Table - Router Forums
post #1 of 8 (permalink) Old 10-05-2009, 11:08 AM Thread Starter
Default Plans for Building a Routing Table
can anyone forward me a link for the "plans" on building my own routing table?
daloia is offline
post #2 of 8 (permalink) Old 10-05-2009, 11:13 AM
Cassandra's Avatar
First Name: Cassandra
Hi Dean:
Welcome to the forums!
Good thing that you're building your own. There are many plans out there (as others will list.) However, there is the joy of designing one's own. When one designs one's own table, that table is custom to the needs of the person doing the design.
Cassandra
Carpe diem, quam minimum credula postero
http://www.panoramio.com/user/5924351
Cassandra is offline
post #3 of 8 (permalink) Old 10-05-2009, 11:26 AM
Bob N's Avatar
First Name: Bob
Dean,
Cassandra makes a good point. You may want to poke around in the galleries of our members here to "steal" some great design ideas you can use on your own build. They are not all that hard to design/build and we have some real masterpieces in the archives.
Bob N is offline
post #4 of 8 (permalink) Old 10-05-2009, 01:10 PM
First Name: Dennis
I did a quick search and found this. HTH
toolcrib.com/blog/2007/03/03/toolcribcoms-ultimate-guide-to-free-router-table-plans/
farrout is offline
post #5 of 8 (permalink) Old 10-05-2009, 01:54 PM
google.com
danconway327 is offline
post #6 of 8 (permalink) Old 10-05-2009, 06:50 PM
Cassandra's Avatar
Hi Dean:
Some points to consider:
1. Separate the table top design from the cabinet design.
2. Do the table top design before starting to do the cabinet design.
3. Determine the size of your table top. There are a whole host of possibilities for table top size, ranging from say 12x18 inch up to 24x48 inches, or more. What you intend to use the router table for (smaller work-pieces vs larger work-pieces) guides you to the size of the top.
4. Typically, the table top is an MDF core (usually 1 to 1-1/2 inch thick) with hardwood edging.
5. The MDF needs to be sealed against moisture. This can be done via a number of techniques. For example: laminating, oiling (e.g. Tung or Danish Oil), or waxing.
6. Consideration needs to be given to mounting the router to the top. Most people go with an insert plate.
7. Optionally, one can add a router lift.
8. Once one is comfortable with the table top design, then one can turn one’s attention to designing the “underpinnings.” First question to be answered is: “Do I build a cabinet or a stand?”
9. Some things to consider for the underpinnings include: (1) what is a comfortable work surface height above the floor, (2) how much should the table top overhang the underpinnings, and (3) is the router table to be fixed in place within the workshop or should it be easily moved about (i.e. casters?)
10. If building a cabinet, thought should be given to things like bit storage, tool storage, easily-accessible power switch and dust collection.
Quite a few things to consider, right?
Cassandra
post #7 of 8 (permalink) Old 10-06-2009, 01:29 AM
First Name: martin
years ago i made one using 1/2" thick sheet of this, Phenolic - Phenolic Sheets - CANVAS Grade C Order Online some REALLY nice stuff, i was working in a machine shop at the time so i got a big discount on the size i needed.
radios is offline
post #8 of 8 (permalink) Old 10-06-2009, 04:14 AM
First Name: Gerry
Default RT Plans
I'm new to WW. Bought plans from FW magazine. I modified the plans, made it larger and building a cabinet for storage. The original plans had an open design.
It helps to see what other people have built and incorporate your ideas into a design.
One thing I'm learning is to build simple things to do projects better and then build more elaborate projects. Point being I should have built a small RT nothing fancy. Could have been using it for other projects. Once I built the top of my table, I put on saw horses and started to use it.
G.L.
Gmex is offline
Horizontal Router table Plans Hickory Tools and Woodworking 35 01-24-2011 09:32 PM
New to table routing roylandry1970 Table-mounted Routing 8 06-22-2009 11:27 AM
Kreg Router Table Plans tauras Table-mounted Routing 0 10-24-2008 04:40 PM
Router Table Plans TexasTed Project Plans and How To 1 09-12-2006 05:59 PM
