What's the best way to seal MDF? - Router Forums
post #1 of 22 (permalink) Old 10-22-2009, 08:13 PM Thread Starter
First Name: Mischa
Default What's the best way to seal MDF?
Besides laminating with Formica, what is the best way to seal MDF with the purpose of using it as a router tabletop? I'm in North Carolina where it gets quite humid in summer, and I only have easy access to 'normal' MDF, not any particularly moisture-resistant version.
Thanks so much! MM
xvimbi is offline
post #2 of 22 (permalink) Old 10-23-2009, 02:01 PM
First Name: Brad
Thanks so much! MM
A couple coats of paint on the open ends or polyurethane. I prefer the latter.
Just remember what my father always said, " Half the people in this world are below average!", and everything in life will make a hellova lot more sense.
timbertailor is offline
post #3 of 22 (permalink) Old 10-23-2009, 04:39 PM
Twill57's Avatar
Any wipe on oil will work. I have used shellac, poly and tung oil. MDF will drink up quite a bit.
Twill57 is offline
post #4 of 22 (permalink) Old 10-24-2009, 08:44 AM
First Name: Gary
Sealing is one thing. Surface hardness is another matter. I guess I wonder why you would not wish to use Formica for your router table surface. I used a router table for 25 years with a formica top with little wear. I suspect a top of MDF only would not last as long.
garybaritone is offline
post #5 of 22 (permalink) Old 10-24-2009, 10:19 AM
Ghidrah's Avatar
First Name: Ronald
Formica protects against severe dings from impacts too.
I don't baby my tools, I'm wicked careful with heavy and or sharp objects, yet I know, (from past events) due to a small/crowded shop I'd have a number of divits in the table top without the formica.
Ghidrah is offline
post #6 of 22 (permalink) Old 10-24-2009, 01:00 PM Thread Starter
First Name: Mischa
Thanks for the replies, so far.
I realize that Formica has some protective features. However, I have to get out of my way to obtain some of it. At this point, I want to get a working router table in an uncomplicated fashion and use it while I think about the next version. In addition, I was interested in that question in general, because I'd like to seal some jigs made with MDF.
Thanks again. MM
xvimbi is offline
post #7 of 22 (permalink) Old 10-24-2009, 02:04 PM
Bob N's Avatar
First Name: Bob
Hi Mischa,
I have found Poly to work well for my needs in that area. Usually I have some sitting on the shelf that is getting old so it is a good excuse to use it up before buying a fresh can
Bob N is offline
post #8 of 22 (permalink) Old 10-24-2009, 03:27 PM
I have had good luck with "Watco" oil. Any shade will do.
Admittedly, it is not as resistant to "dings" as laminate, but is a heckuvalot cheaper. A couple coats left to properly dry, followed by an application of paste (Johnson's) wax gives a slick surface.
This method also works well for workbench tops. Any dribbles of glue or finish is easy to scrape off.
Happy Halloween!
a1tomo is offline
post #9 of 22 (permalink) Old 10-24-2009, 05:52 PM
BigJimAK's Avatar
Thanks so much! MM
You've just asked a "What company makes the best car" kind of question.
In essence you want to control the rate of moisture absorbtion from the air. As in wood finishing where some prefer wax, some oil, some poly, here some prefer laminate, some hardwood, some wax, some poly, some shellac and others. Any will work. Some are less $$, some require more or less maintenance, and (a big) part is what looks best to you. It's *your*table.
BigJimAK is offline
post #10 of 22 (permalink) Old 10-24-2009, 07:02 PM
drasbell's Avatar
Try boiled linseed oil it works great.. thats what I use,,
Life: Is a runaway train you cant wait to get on.
drasbell is offline
Red Oak tannin bleed and spraying Poly varnishes fbenkautz The Finishing Touch 16 04-16-2009 09:48 AM
should one seal the underside of a tabletop? jer760 The Finishing Touch 7 01-29-2008 12:12 AM
Gluing Joints nzgeordie The Finishing Touch 3 04-12-2007 09:37 AM
