height adj lubricant ? - Router Forums
post #1 of 6 (permalink) Old 10-23-2009, 10:51 AM Thread Starter
First Name: Mike R
Default height adj lubricant ?
Hello
I have a Freud FT1700VCE V3 and I am having some problems with binding up and being hard to adjust the height where the motor goes thru the stationary base I have mounted to the table.
Can I or should I lubricate it ? I was thinking a teflon spray like we used to put on the table saws or is there a cheaper/ easyer solution ? Any advice ?
awoodnut is offline
post #2 of 6 (permalink) Old 10-23-2009, 11:23 AM
Talking
Originally Posted by awoodnut View Post
Hello
Mike - mine was a little bit rough when I first got it but it's smoothed out now. I used a little "wet graphite" lube. It's a graphite lube in a wet spray. I spray the stuff on and usually let it set overnite then wipe down any excess. I get mine at NAPA. Seems to last a long time. I would think teflon would be OK also.
I don't recall for sure but I may have tweaked the lock adjustment a bit also.
John Schaben
jschaben is offline
post #3 of 6 (permalink) Old 10-23-2009, 11:46 AM
Empire Bit & Blade Lubricant - 2oz.-Sommerfeld's Tools For Wood
post #4 of 6 (permalink) Old 10-23-2009, 03:09 PM Thread Starter
First Name: Mike R
Thanks bob I will give that a try.
awoodnut is offline
post #5 of 6 (permalink) Old 10-23-2009, 06:20 PM
Mike Wingate's Avatar
First Name: mike
Try a wax candle. A proper dry lubricant.
Mike Wingate is offline
post #6 of 6 (permalink) Old 10-25-2009, 09:09 AM
First Name: George
Mine did the same thing. I contacted Freud and they sent me a new kit for the adjuster. Their customer service dept. has been tops for me.
Best Regards,
George II
George II is offline
Building a New Router Table-What's the Ideal Working Height? gerrym526 Table-mounted Routing 12 07-19-2014 08:49 PM
Need a router w/ accurate and easy height adjustment in table use. WoodTroll Table-mounted Routing 26 04-10-2011 12:11 PM
Above table adjusters... do you lock your router height? AlanZ Table-mounted Routing 15 08-26-2009 02:44 AM
Height of fence riser? Billat908 Table-mounted Routing 2 08-12-2009 07:06 PM
Not enough height!! Tabb Table-mounted Routing 12 11-23-2004 12:38 PM
