top material? - Router Forums
post #1 of 3 (permalink) Old 10-25-2009, 06:04 PM Thread Starter
Default top material?
Hello,
I am looking to upgrade the router table in my shop. I have a 7539 PC 3-1/4 hp plunge router and a Bosch 1617EVS with fixed base and plunge that work well. I am considering the Bench Dog cast iron top with the Rockler FX lift for the Bosch 1617 router. I would be interested in using the PC 7539 if I can find a reasonable priced lift. Not sure I need the extra HP. Most cutting will be hardwoods. Has anyone bought the cast iron top? If so how was the surface finish?
Tom
springwoodindustries is offline
post #2 of 3 (permalink) Old 10-25-2009, 07:09 PM
Hamlin's Avatar
First Name: Ken
Hi Tom,
Welcome to the router forums.
Ken
"A VETERAN"
Hamlin is offline
post #3 of 3 (permalink) Old 10-25-2009, 09:15 PM
First Name: Gary
See my gallery for a router table I built with the Bench Dog cast iron top (the blue one). The surface finish is very good on the top. About the same as a Delta table saw top. Also in my gallery is a picture of the Bench Dog cast iron router table saw extension wing mounted on my Unisaw. Both have Bench Dog prolifts mounted in them.
garybaritone is offline
template material mountain monkey Guide Bushings and Templates 37 01-05-2009 08:49 AM
Trouble initializing material.. or table? JCPowell CNC Routing 0 11-11-2008 08:30 AM
Table top material questions majn555 Table-mounted Routing 18 11-06-2008 09:49 AM
Material for Router Table Top johnpierce Table-mounted Routing 3 03-02-2006 08:31 AM
Table Top Material rh111 Table-mounted Routing 4 04-19-2005 03:35 AM
