MLCS cast iron ext wing - Router Forums
post #1 of 2 (permalink) Old 10-27-2009, 09:32 PM Thread Starter
Default MLCS cast iron ext wing
Has anyone had experience with this extension wing. I took a leap of faith and got one from amazon. It just arrived and looks solid and well machined.
It is intended to mount on my Unisaw (with the addition of another 10" extension to the right of the blade.
My problem is that it has only 8" of table top space between the edge and the router spindle. In that 8" is the miter slot. Seems a bit short and that some workpiece won't have much to ride on. My old bosch table has 12". I am planning construction of 30 or so raised panel doors/drawer fronts and am worried the panels will rock.
Any feedback is greatly appreciated as this guy was expensive and if it's not better than sliced bread it's going back.
Paul
eoddiver is offline
post #2 of 2 (permalink) Old 10-27-2009, 10:45 PM
Talking
Hi Paul,
I haven't got many critcisms of MLCS, most everything I get from them is pretty good. But, many, many times the pictures of the stuff on the website seem to be significantly out of proportion to what the product really is. I just went and looked at the extension table and didn't notice how close that was without studying the picture and comparing the printed specs.
That said, I see your position. I haven't got a whole lot more on the operator side of the spindle than you do but I don't do raised panels either. I wonder if you can't put the fence on the other side of the spindle and run them left to right, on the backside of the bit so to speak. Or, using a vertical bit, the panels would be run on edge anyway.
John Schaben
jschaben is offline
MLCS Cast Iron Router Table mshaf23783 Table-mounted Routing 9 06-28-2017 12:57 PM
cast iron tops? springwoodindustries New Member Introductions 4 10-26-2009 12:34 AM
BlackJack Cast Iron Extension Router Wing Puzzline Table-mounted Routing 18 04-21-2009 01:53 AM
need advice for inserting rosseau router plate into bench dog promax cast iron table sf_basilix Table-mounted Routing 7 02-21-2008 06:00 PM
Cast Iron Router table in table saw reierme Starting Off 4 11-28-2007 07:27 PM
