Building first table-- need advise on router plate - Router Forums
post #1 of 10 (permalink) Old 10-30-2009, 04:23 PM Thread Starter
First Name: Tushar
Default Building first table-- need advise on router plate
I have PC 690 Router and plan to buy a better router (Craftsman Pro variable speed 2 1/4 hp) when it comes on sale within a year.
I am shopping at Rockler for the fence, doo-dads (Accessory kit) and an Aluminum plate. I am looking at their Discounted (Closeout) Aluminum plates.
The question is what plate I should order from Rockler for Craftsman Pro and whether Craftsman Pro can use same plate as PC690 Router. From the description seems like a generic plate for most routers out there but doesn't mention the Craftsman Pro 2 1/4 hp router specifically:
*Mounting holes for item #35265 will match for Porter Cable 7529/690/693 routers, Makita 1100-1101 series and bases, Bosch 1617EVS, 1618, DeWalt DW616, DW618 series routers.
Select Plate to fit your Router:
35265 Plate for Porter Cable 7529/690/693, Makita, Bosch & DeWalt*
21810 Rockler Router Table Plate for PC 890 Series
67349 New-Router Table Plate for Porter Cable 8529 Routers
Anything else I should buy for this plate (like extra inserts?)?
gbuy2001 is offline
post #2 of 10 (permalink) Old 10-30-2009, 04:34 PM
dutchman 46's Avatar
First Name: Howard
Hello and welcome, It all depends on what you want. A lot of Harbor Freight plates are used. My guess is that you can wait and see. or run a search roe Harbor freight. Thanks for asking, and you will receive other post
John 3:16
dutchman 46 is offline
post #3 of 10 (permalink) Old 10-30-2009, 05:15 PM Thread Starter
First Name: Tushar
Thanks, but I am sticking with Rockler since I'm already placing an order with them for pullouts, hinges, a router fence so it's not much more to add a plate. My question is really what pattern of holes the Craftsman #28190 uses. Is it same as Porter Cable 7529/690/693 routers, Makita 1100-1101 series and bases, Bosch 1617EVS, 1618, DeWalt DW616, DW618 series router or is it different than all of these? I'm hoping it is same as one of these so I can mount my PC in the table for now and switch to the more powerful Craftsman when it comes on sale.
gbuy2001 is offline
post #4 of 10 (permalink) Old 10-31-2009, 03:13 PM
Are you sure you want to go the Craftsman route on choosing a router. I have made three router tables for both home and use at school and I have found PC routers to have performed the best. I ended up burning out a 1 1/2 hp and 2 1/4 hp routers in a school shop. I ended up with the three hp porter cable that handled everything we could throw at it.
brownie58 is offline
post #5 of 10 (permalink) Old 10-31-2009, 04:15 PM
Hamlin's Avatar
First Name: Ken
The newer craftsmen routers are far better than their older models ever could have been. Their 2 1/4hp combo kit usually sells around the $119.00, since "Black Friday" is coming up soon, keep an eye on their special.
Ken
"A VETERAN"
Hamlin is offline
post #6 of 10 (permalink) Old 10-31-2009, 04:33 PM
RStaron's Avatar
First Name: Ron
You will most likely have do drill the plate to fit the Sears router. I have an older Sears router and it does not match the Porter Cable mounting holes.
RStaron is offline
post #7 of 10 (permalink) Old 10-31-2009, 05:15 PM Thread Starter
First Name: Tushar
thanks. re: PC, I'm also very impressed with the unit I have, but the reviews and price for the Craftsman are quite compelling and the comparable PC are out of my price range. I've been happy with the Craftsman products I've owned (I avoid the cheap stuff though) and somehow the brand reminds me of my childhood (my dad ONLY bought Craftsman).
gbuy2001 is offline
post #8 of 10 (permalink) Old 11-01-2009, 09:49 AM
First Name: Howard
The Craftsman has had good reviews in the publications. It is always mentioned as a good buy, price wise. If BJ3 sees this one, He'll post also.
John 3:16
post #9 of 10 (permalink) Old 11-03-2009, 07:37 PM
First Name: martin
i'd say the Bosch 1617EVS is nearly a clone of the 320.17543 craftsman, so that might fit, if not, you'll have to drill new holes.
radios is offline
post #10 of 10 (permalink) Old 11-04-2009, 05:42 PM
First Name: Harry
If you really want Sears, then go for it. Very little to drilling your own holes. There are a number of threads here that will help you, if you need it. I was a Sears fan for many years; but the last 5-6 years has left a bad taste, but at least they have good return policy, if you read the fine print.
Harry, TX
Cut it twice, and it's still too short!
Old_Chipper is offline
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
Inserting a router plate into a table Dr.Zook Lobby 5 04-23-2009 03:32 AM
New router, need table, building dovetail cabinets santana157 General Routing 7 02-02-2009 11:34 PM
Mount router to table plate? Bogydave Table-mounted Routing 10 01-07-2009 02:58 PM
need advice for inserting rosseau router plate into bench dog promax cast iron table sf_basilix Table-mounted Routing 7 02-21-2008 06:00 PM
