router bit layout - Router Forums
post #1 of 11 (permalink) Old 10-31-2009, 11:42 AM Thread Starter
Default router bit layout
I am using a 3/4 core box bit, and need to route about 13 1/2 inches, stop and skip an area about 1 1/2 inches, then router another 3 1/2 and I am done..what is the best way to mark on the top of the router table lines so I know where the leading and trailing edge of the bit is located. figured just tape and a marker, but seems when I draw out the lines from the bit to the table top, they do not equal 3/4 inches?....tks in advance...Dennis
dtaylor is offline
post #2 of 11 (permalink) Old 10-31-2009, 11:58 AM
The simplest way for me is to just mark the left and right edge of the bits cutting profile on a piece of masking tape. Mark the start and stop points on the workpiece.
John Schaben
jschaben is offline
post #3 of 11 (permalink) Old 10-31-2009, 12:31 PM
Mike Wingate's Avatar
First Name: mike
If you do the cuts as 2 separate operations, you can set your stops on the fence, do one cut. Set up for the second and cut. It takes time, but you can be sure of your start and end with a pair of stop blocks at each side of the bit.
Mike Wingate is offline
post #4 of 11 (permalink) Old 10-31-2009, 12:38 PM
Default Ooops
Sorry, didn't read your post closely enough. I use masking tape on the table but I use a combination square to mark the lead/trail. Turn the bit so you are sure to catch the cutting edges.
Stop might work ok for the short cut but I would run out of a place to hang a stop on the 13" one.
Good Luck
John Schaben
jschaben is offline
post #5 of 11 (permalink) Old 10-31-2009, 12:54 PM
First Name: mike
My Incra fence has a lonnnnnnng extension stop.
post #6 of 11 (permalink) Old 10-31-2009, 01:40 PM
First Name: Richard
Hi Dennis. I find the easy way is to use a square and mark the start and stop on the tape and then extend it to the fence. Hope this helps.. Woodnut65
Woodnut65 is offline
post #7 of 11 (permalink) Old 10-31-2009, 03:19 PM
I would definitely agree with Mike on this one. Using stops guarantees perfect, repeatable cuts. Using the masking tape/combination square technique leaves a little wiggle room for mistakes to happen.
Schechner is offline
post #8 of 11 (permalink) Old 10-31-2009, 07:06 PM
First Name: mike
If you dont have stops, clamp some wood to the fence or table, in the right place. Stops work and are an easy solution.
post #9 of 11 (permalink) Old 10-31-2009, 07:13 PM
Hamlin's Avatar
First Name: Ken
Start and stop marks on both your work piece and your fence is just as accurate. Time wise, setup for both ways,(Stop blocks), are equal.
Ken
"A VETERAN"
Hamlin is offline
post #10 of 11 (permalink) Old 10-31-2009, 07:16 PM
Hi
Clamp some scrap stock to the fence for stop blocks,make all the long runs and then reset the stop blocks and make all the short runs..they will all come out just right..and all the same...
Rigid Model R2900 Router Combo and Ryobi Model A25RT02 Router table bigdave720 Table-mounted Routing 12 04-05-2012 07:27 PM
Router Recall (PC, SEARS, RYOBI) Birdflu General Routing 5 02-23-2012 10:01 PM
How do I mount a Router to a table demaX Table-mounted Routing 3 04-16-2009 06:56 AM
