My base plate is suddenly too tight - Router Forums
post #1 of 5 (permalink) Old 11-01-2009, 01:58 PM Thread Starter
Bob N's Avatar
First Name: Bob
Default My base plate is suddenly too tight
I have the Oak Park router table and their phenolic vacu-plate base plate and everything has fit well until I went out to the shop today and had to tap my base plate into and out of the opening with a dead blow hammer. It has become too tight for comfort and I am sure it has to do with moisture from all the rains and flooding we have had lately. I have my shop humidity under control since the flood, but I think my table may be permanetly affected for some reason.
I need some advise on a solution. Should I try to lightly sand the phenolic base plate on 2 joining sides and corners or work on the table opening? What other alternatives am I overlooking?
HEEEEELLLLLP!
Bob N is offline
post #2 of 5 (permalink) Old 11-01-2009, 02:02 PM
Hamlin's Avatar
First Name: Ken
Hi Bob,
I've had a similar problem in the past myself. I simply took a file and filed down all 4 corners just slightly. Not much is needed. You'll find, you only need to work on the corners not the edges themselves.
Ken
"A VETERAN"
Hamlin is offline
post #3 of 5 (permalink) Old 11-01-2009, 02:05 PM
Hi Bob
Do you have a heat gun/hair dryer if so use it with care on the top,,without the plate in place,, it may pull the humidity out ,,if not sand the plate but with care again..
HEEEEELLLLLP!
post #4 of 5 (permalink) Old 11-01-2009, 02:13 PM Thread Starter
Bob N's Avatar
First Name: Bob
Thanks guys, I'll try my heat gun first and if that don't fix it, I'll work on the corners only like Ken suggests.
Bob N is offline
post #5 of 5 (permalink) Old 11-01-2009, 03:21 PM
BigJimAK's Avatar
Once it fits, seal the wood??
BigJimAK is offline
Closed Thread
Triton Router Base Plate garbo.hunter Triton 10 08-09-2013 09:00 AM
Router plate as base plate?? xplorx4 General Routing 6 05-24-2009 06:19 PM
Base Plate Help CanuckGal Portable Routing 47 05-16-2009 04:10 PM
choosing a base plate ... reikimaster Table-mounted Routing 5 01-13-2006 10:37 PM
Centering Base Plate -Sam- General Routing 15 01-04-2005 10:15 AM
