Fence design - Router Forums
post #1 of 11 (permalink) Old 11-03-2009, 11:14 AM Thread Starter
First Name: Trent
Default Fence design
Hi All,
I am making a split fence for my newly built router table.
What size should I make the opening for the bit to recess into the area of the fence? I currently have it cut to 2" high and 3" wide. Is this a good size for most bits or should I go larger?
I am a newbie wood worker and am planning on making some raised panel doors but cannot imagine using bits larger than that anytime in the near future.
Is a 2 1/2" dust collector port for the fence large enough?
It is a basic L design with recess for the router bit and a sliding split fence on the face. Planning on 4" fence with 2" sub-fence. I will be adding a T-Track 1/2" above the sub-fence for accessories.
Thoughts?
the_nite_owl is offline
post #2 of 11 (permalink) Old 11-03-2009, 12:07 PM
Bob N's Avatar
First Name: Bob
Hi Trent,
I think the sizes you mentioned sound about dead on the money. A 2 1/2 " dust port is most adequate for the job.
Waiting on pictures when you finish
Bob N is offline
post #3 of 11 (permalink) Old 11-03-2009, 01:39 PM
dutchman 46's Avatar
First Name: Howard
Hello Trent: I would say that is a great place as far as measurements. If you are making a split fence, you should be able to move the fence apart. That would allow you to adjust the fence for a larger bit. If you make the rt, and the lt hand side able to slide, you can also make the fence adjust out, on the out feed side, that will allow you to plane on it. The adjustment is only 1/32, or so and your edge is planed.Your frnce must line up exactly for most planing operations. Good luck
John 3:16
dutchman 46 is offline
post #4 of 11 (permalink) Old 11-03-2009, 07:17 PM
First Name: Henry
I made several fence "face plates" that fit over my base fence - made them out of plywood and they are a tight fit onto my base fence without screws. I fit the blank faces and then slowly push the fence into the bit to get a perfect cut-out - works very well with vertical raised panel bits.
ccmnova is offline
post #5 of 11 (permalink) Old 11-04-2009, 06:50 AM Thread Starter
First Name: Trent
I have considered this but do not see an easy way to adjust one side in and out other than to just slip a shim in behind it when needed.
post #6 of 11 (permalink) Old 11-04-2009, 03:53 PM
BigJimAK's Avatar
Shims work!! Some keep a old deck of playing cards in their shop for that purpose. :-)
BigJimAK is offline
post #7 of 11 (permalink) Old 11-04-2009, 05:26 PM
First Name: Howard
The playing deck works, and also, you can mike your card, so you know how much you are removing. You can use anything that is thin, and you can just loosen the retainers that hold the split fence. The cards can be altered so they can slip around the bolts. Aways shim all bolts the same on one fence side, or you will not remove material straight.
John 3:16
post #8 of 11 (permalink) Old 11-05-2009, 08:52 AM Thread Starter
First Name: Trent
I just missed out on getting a free jointer so I will probably have to rely on doing some edge work on the router table. I may just make a slip in template and insert it from the bottom of the fence when needed. I cannot go easily from the top as I will have T-Track above the sub-fence for accessories.
Speaking of T-Track though I was looking at a Jessem table last night and the sliding fences are mounted on T-Track and face adjustable rather than from the back. I am considering doing this by adding T-Track to each side of the fence for the sub-fences to slide into. Seems a reasonable way of setting it up and then I can make a bunch of spare sub-fences with the counter sunk screw holes in them.
On one web site they recommended having a gap below the fence for saw dust to escape into rather than getting in the way of the piece. Any thoughts on that? My inclination is to make them meet the table and just keep things clean as I work.
post #9 of 11 (permalink) Old 11-06-2009, 04:04 PM
First Name: Ken
Send a message via MSN to Kenman101
I use 3" opening with a dust port that has a 2 1/2 opening. The dust port is longer and covers up all of the opening. Then you can use 2 1/2" hose or an adaptor to 4" hose.
Kenman101 is offline
post #10 of 11 (permalink) Old 11-06-2009, 10:33 PM
Bogydave's Avatar
First Name: Dave
Here's one more idea:
make different "drop in" inserts for bits or others uses
http://www.routerforums.com/table-mo...html#post87230
Name:	rpd6 pnlbit rails.JPG
Name:	RT DC 1.JPG
Name:	RT DC 3.JPG
Name:	RT DC 4.JPG
Life isn't right, wrong or fair. Life just is.
Bogydave is offline
  LinkBacks (?)
LinkBack to this Thread: https://www.routerforums.com/table-mounted-routing/17417-fence-design.html
Posted By For Type Date
Untitled document This thread Refback 03-02-2010 02:45 PM
Face Lift for the Router Fence bobj3 Jigs and Fixtures 8 04-07-2013 09:21 AM
Some Thoughts on Fence Control Gilbear Table-mounted Routing 21 04-16-2010 05:38 PM
Which material for fence onap Table-mounted Routing 25 04-23-2009 06:23 AM
Pivoting fence arc vs distance? Bogydave Table-mounted Routing 16 01-14-2009 08:49 PM
