Bosch 1617EVS - Router Forums
post #1 of 24 (permalink) Old 11-03-2009, 06:53 PM Thread Starter
First Name: Henry
Default Bosch 1617EVS
New to the site. I have two Bosch 1617 EVS. One is mounted in an old but heavy duty router table. The other I use with the plunge base. I have an additional fixed base and want to mount it to the underside of an old work table I have just for cutting raised panels with the horizontal bits. I have been using vertical raised panel bits in the old router table with a high fence I custom made and its OK - but I'd like to have a separate station only for raised panels and one where I could use the horizontal bits (my old table is made out of aluminum and the center hole is only 2.5 inches max.
What's the best way to mount the fixed base to the underside of a heavy table (1 inch thick pressed board with laminate top) - will I have to recess the underside is is the thickness OK. Also, what hole dia would be suggested to accommodate horizontal raised panel bits. For the fence, I am thinking of just clamping a piece in place when needed.
Thanks for any help you can offer !
ccmnova is offline
post #2 of 24 (permalink) Old 11-03-2009, 07:28 PM
Welcome aboard
vikingcraftsman is offline
post #3 of 24 (permalink) Old 11-03-2009, 08:17 PM
First Name: Harry
Hello Henry,
Pressed trash is not going to last long, if there is any humidity in your shop. You can seal all sides, that will help a little. MDF is a better choice. I would suggest you get the 20.00 plate from HF. They are on sale pretty often. You get a set of inserts with it. A one inch table eats up a lot of needed depth.
Harry, TX
Cut it twice, and it's still too short!
Old_Chipper is offline
post #4 of 24 (permalink) Old 11-03-2009, 09:26 PM
Bogydave's Avatar
First Name: Dave
I put a HF in a 1-1/2" thick table;
Got help from bj3 & others here, worked & is working fine
link:
Router Forums - View Single Post - AK router table/stand progress
Others may chime in with ideas also
link to whole table build #9 is the above page: http://www.routerforums.com/table-mo...html#post87124
Life isn't right, wrong or fair. Life just is.
Bogydave is offline
post #5 of 24 (permalink) Old 11-04-2009, 05:43 PM Thread Starter
First Name: Henry
Ok this may be a dumb question - what is "HF" ?
I saw 3/4 inch MDF at Lowes for $25 for a 4 x 8 sheet. Is MDF suitable as is or does it need to be sealed and the top laminated ?
ccmnova is offline
post #6 of 24 (permalink) Old 11-04-2009, 07:13 PM
First Name: martin
i'd say laminate it, without laminate, if you get a drop of water on it, it'll bubble up there, like say a bead of sweat, or a drink whatever. also, the wood will slide much easier over laminate.
radios is offline
post #7 of 24 (permalink) Old 11-06-2009, 04:08 PM
First Name: Ken
Send a message via MSN to Kenman101
I would use an router table insert and MDF. One thing to note with the bosch. If you cut a lot of mdf, the dust clogs the power switch. The router will sometimes turn on and sometimes not. A little compressed air and your good to go.
Kenman101 is offline
post #8 of 24 (permalink) Old 11-06-2009, 09:02 PM Thread Starter
First Name: Henry
You're right about the switch - should be covered. I love the Bosch though - it's a great router and that's why I have two. My old 1617 evs sound "different" than the new one - the new one is quieter and a much better soft start.
ccmnova is offline
post #9 of 24 (permalink) Old 11-06-2009, 09:46 PM Thread Starter
First Name: Henry
Now I had a thought - is a plate even necessary for a router like the 1617 evs which comes out of the base easily and can be switched from base to base ? Why couldn't I just have a hole in the table top and fit the base to the underside without a plate at all ? Would need some kind of ring spacers and some way to mount them - also, I'm not sure of the mounting thickness limit if this would be a detriment to the height adjustment.
ccmnova is offline
post #10 of 24 (permalink) Old 11-06-2009, 10:21 PM
First Name: martin
if you mount it right to the top, you're going to lose the table thickness in height adjustment.. a router plate is only 1/4" thick. if you routed the table top to 1/4" thick, and mounted it to that, it would be dangerous, and the router could break loose.. so it's better to use a router plate.
radios is offline
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Bosch 1617EVSPK or Bosch 1619EVS LBrandt Table-mounted Routing 25 01-19-2012 09:44 AM
Bosch 1617EVS router repair chiswoo Starting Off 6 07-02-2007 05:30 PM
