Insert Rings advice - Router Forums
post #1 of 11 (permalink) Old 11-12-2009, 01:03 PM Thread Starter
First Name: Greg
Default Insert Rings advice
Hi,
I am going to make a basic router table and have aquired a piece if 3/8 aluminium plate about 12 x 9 in size
I was just going to cut a 3/4 inch hole in it mainly to use 1/2 inch straight bits.
After I started to think about it and read,I am starting to think that I will probably end up using this for other bits (Rounding over etc) and the 3/4 hole will be too small.
I was thinking of cutting a 2inch square hole in the aluminium and rebating it to take 1/4 perspex or plastic to use as an insert "ring".
I thought square for ease of cutting.
Firstly I am not sure if I can machine the aluminium easily to cut the rebate and secondly if the square perspex/plastic will work.
All the ones I have seen are round for some reason????.
OR, am I wasting my time with the ring insert idea?
Thanks for any advice.
Regards
Greg
gregmw is offline
post #2 of 11 (permalink) Old 11-12-2009, 03:29 PM
First Name: Bob
Hi Greg, It really depends on what you need your table to do for you. If you're certain that at some point later in time that you won't need large/wider bits, then keep the hole just a tad larger than the largest bit you'll use. Kinda like you... I don't run huge bits on my little table, so I have a 1" hole in the top... nice n simple. Sure, you can get the nice pre-cut mounting plates with replaceable inserts... pretty cheaply these days, but if you don't need it, why bother.
anotherBob is offline
post #3 of 11 (permalink) Old 11-12-2009, 07:58 PM
dutchman 46's Avatar
First Name: Howard
Hello Greg; I think that i can refer you to aother link.
http://www.routerforums.com/guide-bu...ase-plate.html
I hope it will get you there, I can tell you that i would go with the round insert hole. the teason is that almost all companies make round inserts. Welcome and enjoy.
John 3:16
dutchman 46 is offline
post #4 of 11 (permalink) Old 11-12-2009, 09:14 PM
Hi Greg
It's not just for using the big bits but you can use the bigger hole to switch the bits out from the top side of the table table with a offset wrench..you don't need a router that puts the chuck above the table top to change out the bits with a bigger hole..
Off-Set Router Bit Wrench
Router Accessories
You can bend the wrench that came with the router to save a buck or two..all you need is some heat..
http://www.routertechnologies.com/in...C%20wrench.pdf
http://www.routertechnologies.com/in...%20generic.pdf
post #5 of 11 (permalink) Old 11-12-2009, 09:58 PM
drasbell's Avatar
A while back I posted this http://www.routerforums.com/table-mo...r-table-2.html
Our tops are close to the same. find someone with a lathe big enough, to chuck the plate and turn your inserts out then you can make as many inserts as needed,
All though as Bobj3 stated the aluminum can make unwanted marks on your work keep it well waxed,
Life: Is a runaway train you cant wait to get on.
drasbell is offline
post #6 of 11 (permalink) Old 11-13-2009, 01:36 AM Thread Starter
First Name: Greg
Thanks Guys for the fast replies.
I might take the aluminium to a machine shop and see what they will charge to machine a rebate in it.(after I get the inserts)
Its funny,but by the time you buy the Aluminium and get it machine,then get the inserts,I reckon its cheaper to buy a plate already made up!
Oh well
Hey Bob,They are the words from a great song.Just got it last week!
Thanks again
Cheers
Greg
gregmw is offline
post #7 of 11 (permalink) Old 11-13-2009, 09:19 AM
First Name: Bob
Just in case there might be another cave-dweller out there...:
YouTube - Billy Currington - People Are Crazy: Closed-Captioned
post #8 of 11 (permalink) Old 11-13-2009, 10:04 AM
Hi Greg
Your welcome for my small part, it's hard to beat the HF plate,, 20.oo bucks,,and it's all done...they sale that same plate every where..
- Harbor Freight Tools - Quality Tools at the Lowest Prices
I'm not a real big fan of ALUM....it will put the little marks on the stock that's a real pain to get off the stock..many sale and make ALUM. plates but they are coated and in time they will do the same wax works but then you are putting wax on the stock that will seal the wood..it's not like putting wax on wood stock,it sinks into the wood but the alum., it can't sink in..so to say it gets transfered to the lumber..and will show up at finish time.. it's true you can wipe the stock down with some paint thinner /or ? to remove the wax but why not use the right plate to start off with....not to say anything about raising the grain and re-sanding it down..
Oh well
Thanks again
Cheers
Greg
post #9 of 11 (permalink) Old 11-18-2009, 01:24 PM Thread Starter
First Name: Greg
Hi Greg
Hi Bob,
I just go a shipping quote from Harbour Freight which makes the total cost about $70.00. US
Is the quality of their plates pretty good.
I can pick up the "Woodpeckers TLR router plate" for about $20.00 more down here,but they are out of stock at the moment.
I appreciate your input and advise.
Regards
Greg
gregmw is offline
post #10 of 11 (permalink) Old 11-18-2009, 02:29 PM
Router accessories
Q: How about Foreign Shipping?
A: Sure, MLCS is happy to process orders for our international customers. We can ship to most countries. Shipping charges are based on the size and weight of the order and the country to which we are shipping. International shipping charges will be displayed accurately in your online shopping cart (subject to offline verification). Most orders ship via 1st Class Mail International and Priority Mail International. However, not all shipping methods displayed are available to all countries due to insurance requirements. Please note that customs duties, taxes, and other import fees may be imposed on shipments by some countries. MLCS cannot be responsible for these charges. We urge you to check with local authorities regarding these charges prior to ordering if you are not already familiar with them. Please check the appropriate box in the shopping cart indicating your acceptance of any duties and taxes. We will not be able to process your order without this verification.
Hi Bob,
Regards
Greg
Tweaking CMT aluminum insert rings? AlanZ Table-mounted Routing 7 01-09-2009 05:14 PM
ZC Insert kolias Tools and Woodworking 7 01-01-2009 10:17 PM
need advice for inserting rosseau router plate into bench dog promax cast iron table sf_basilix Table-mounted Routing 7 02-21-2008 06:00 PM
Bench Dog Advice needed LonePalm Table-mounted Routing 1 01-13-2008 01:49 PM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 01:08 PM
