Lexan/polycarbonate - Router Forums
post #1 of 13 (permalink) Old 11-14-2009, 08:39 PM Thread Starter
First Name: Henry
Default Lexan/polycarbonate
Has anyone used these materials for router bases or for support plates ?
ccmnova is offline
post #2 of 13 (permalink) Old 11-14-2009, 09:30 PM
First Name: Bob
Yes used lexan and was a good alternative to an expensive plate. But for $19.99 a plate is available online from Harbor Freight that looks exactly like the one in the Peachtree catalog measuring 9" x 12"
rtunas is offline
post #3 of 13 (permalink) Old 11-18-2009, 03:24 PM
Mike Wingate's Avatar
First Name: mike
Yes, it is not crystal clear, but it is tough. My previous router table top was made from a 1/4" piece.
Mike Wingate is offline
post #4 of 13 (permalink) Old 11-19-2009, 07:45 PM Thread Starter
First Name: Henry
I believe that lexan is available at Lowes. etc. but I don't know in what thickness - will check and advise.
ccmnova is offline
post #5 of 13 (permalink) Old 11-21-2009, 07:28 AM
First Name: Thrifty
Lowe's "might" have 0.250" thick material, but I really doubt it. I would suggest checking with a local plastic's distributor for some "odd or small-size" cuts/drops of 0.375" thick acrylic or Lexan. You might get a freebie that was headed to the dumpster. Clear is best for visual access, any color will work.
Being in Pittsburgh, you should have a number of local options for this type of material, but you'll have to look for industrial supply houses.
Thrifty Tool Guy is offline
post #6 of 13 (permalink) Old 11-21-2009, 08:10 AM
Twill57's Avatar
I have used several of Lexan like products with great success. Both as a table insert and for base plates. If you have a local plastic shop stop and check for scraps, which are usually sold by the pound. Most of the plastics machine with wood working tools, but you have to adjust for the characteristics of the plastic.
Twill57 is offline
post #7 of 13 (permalink) Old 11-21-2009, 03:25 PM Thread Starter
First Name: Henry
They do have 1/4 inch lexan at Lowes - it doesn't seem to be absolutely rigid - maybe it was the larger piece I was looking at.
ccmnova is offline
post #8 of 13 (permalink) Old 11-21-2009, 05:09 PM
Take a hard look at ploy.cutting boards,they are very cheap and you can find them every where,,,Kmart/Target/HD/Lowes .
1/4",3/8",1/2" thick the norm 6" x 6" to 24" x 24" is the norm..most are white, and are very strong ,the higher end ones are UHMW ..
post #9 of 13 (permalink) Old 11-21-2009, 05:18 PM
BigJimAK's Avatar
It may depend on the weight of the router but 1/4" Lexan seems pretty thin to me for a router plate. It may well hold the weight but as Henry indicates, I think it'd flex too much unless perhaps the plate was kep small.
BigJimAK is offline
post #10 of 13 (permalink) Old 11-21-2009, 05:20 PM
BigJimAK's Avatar
+1 on cutting board stock.. When lexan was mentioned I was thinking of transparency though you may find a thick clear cutting board?
BigJimAK is offline
