Record RPMSR router table problem - Router Forums
post #1 of 10 (permalink) Old 11-18-2009, 02:32 PM Thread Starter
First Name: Peter
Default Record RPMSR router table problem
Hi from a newby!
Never done any woodworking since school (40 yrs ago)
Just got a Dewalt DE625EK and a Record RPMSR router table - put the thing together after much head scatching - not impressed at all with the build quality - but finally got it together and it's actually a nice solid lump of iron.
Mouted the Dewalt - made sure all was clear and plugged it in and BANG flash from the table switch box and all the power in the workshop is gone
The layout...
This is in the UK so I am on 240v and using a 13A circuit
There's a Record supplied on/off pressswitch on the table - plug that into the mains and the router power cable into it. Click the router power switch on and use the table mounted on/off to control the power.
After flipping the trip back on tried again with the router plugged directly into the mains - works a treat.
What I think is happening is that the Dewalt can take 15A max but has a soft start so it ramps up gradually when using it's own switch - but with that switch on and controlling it thru the table switch it takes all 15A and Bang
Anyone confirm this?
But then made my first test joint - only a half lap and it's 1/16" loose - but it's a joint
Peter
pfcooper is offline
post #2 of 10 (permalink) Old 11-18-2009, 05:41 PM
dutchman 46's Avatar
First Name: Howard
The 15 amp switch probably is to lite for the load. The only sugestion is to replace the switch. What happens when you plug into a 15 amp protected switch? The closest thing i can think of is a protected computer 15 amp gfic plug-in. might try. By the way, I want to welcome you here. Others will help you probably better than i can.
John 3:16
dutchman 46 is offline
post #3 of 10 (permalink) Old 11-18-2009, 06:10 PM
First Name: Niall
The router won't draw its full amperage unless its under full load. So when you first turn it on it won't be drawing all that current. Try plugging in something else into the table circuitry and see if the same thing happens. My guess is that the table is faulty.
icehugger is offline
post #4 of 10 (permalink) Old 11-18-2009, 08:20 PM
xplorx4's Avatar
First Name: Jerry
Greetings and welcome to the router forum. Thank you for joining us.
Lamentations 3:22-23
xplorx4 is offline
post #5 of 10 (permalink) Old 11-18-2009, 11:40 PM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the RouterForums Peter.
Dave
the "Doctor"
Dr.Zook is offline
post #6 of 10 (permalink) Old 11-19-2009, 04:37 AM
Bob N's Avatar
First Name: Bob
Welcome to the forum Peter!
Bob N is offline
post #7 of 10 (permalink) Old 11-19-2009, 09:58 AM
Mike Wingate's Avatar
First Name: mike
What happens when you plug another power tool into the tables on/off socket? My 625ek plugs either into the wall, or more commonly into a NVR switch from
CHARNWOOD 240 VOLT NVR SWITCH.
The startup power from the router was too great for the Trend NVR. That may be your problem in the U.K.
Mike Wingate is offline
post #8 of 10 (permalink) Old 11-23-2009, 12:51 AM Thread Starter
First Name: Peter
Howard
That's good info - was not sure if it drew max power in start up or on load
Peter
pfcooper is offline
post #9 of 10 (permalink) Old 11-23-2009, 12:58 AM Thread Starter
First Name: Peter
Thanks I did cursory google for NVR switches but could not find anything - this look to be the job - the Dewalt takes 2kw and this swithch is rated at 2.2kw
All
Thanks for the assist - I reckon the NVR switch as supplied with the table is faulty - will get a replacement
Peter
pfcooper is offline
post #10 of 10 (permalink) Old 12-31-2010, 02:23 AM
just bought ome of these myself
NOW WISH I HADNT
Same problem as you on the switch, it is faulty.
Contacted supplier they sent new switch out straight away different design from the first and that works.
Issue 1. the cast iron bed is not flat !!!! even though it has been surface ground by manafacturer it dips in the middle by 1.5mm
Issue 2. The sliding table does not match the cast iron bed and does not fit in its runners correctly, going ti try opening up the mounting holes of the runner guides to see if that will let sliding table sit down correctly.
Issue 3 Guide fence is a very poor design, had to bolt a brace bar on the back of it to improve, very fiddly to set up.
Alot of money for something poorly constructed
NOT HAPPY WITH IT AT ALL
regards
nick
nicklm is offline
Router Table Completed - Finally! Rutabagared Show N' Tell 12 08-01-2011 09:22 AM
For Sale: RS 500 Router Table - routertabledepot.com sheridan Woodworking Classifieds 1 08-20-2009 09:51 AM
wood feed problem with table router the New Guy Table-mounted Routing 4 02-12-2006 06:05 AM
Opening size in router table problem glassguy1456 Table-mounted Routing 2 02-28-2005 07:09 AM
