Raised Panel Projects - Router Forums
post #1 of 22 (permalink) Old 11-21-2009, 08:54 PM Thread Starter
First Name: Henry
Default Raised Panel Projects
Couple of raised panel projects that really made the dust - lots of raised panels all made w/vertical raised panel cutter.
Name:	Router Work 005.jpg
Name:	Router Work 007.jpg
Name:	cabinet 6 email.jpg
Name:	Router Work 001.jpg
Name:	Router Work 002.jpg
ccmnova is offline
post #2 of 22 (permalink) Old 11-21-2009, 09:03 PM
First Name: George
Hi Henry,
Let me be the first to say, "WOW!!!" Your fireplace mantle makes me want to throw rocks at mine. In the picture, it looks like your high vertical fence attaches over the top of your regular fence. Neat idea!! Do you like the vertical bits better than the horizontal? And what HP router are you using?
Please post more info. on the type of wood and finish on both the mantle and the cabinet. They are truly beautiful.
Capt Splinter is offline
post #3 of 22 (permalink) Old 11-21-2009, 09:19 PM Thread Starter
First Name: Henry
The high fence I made to fit over the normal fence - tight fit w/no fasteners.
I used a vertical raised panel bit with a bosch 1617evs. Only used vertical because the table I have won't accept large diameter bits. I'm making another table arrangement just for horizontal raised panel bits which I haven't tried yet but want to also try. The vertical bit gives a smooth finish with no need to sand (can run at top rpm).
ccmnova is offline
post #4 of 22 (permalink) Old 11-21-2009, 09:38 PM Thread Starter
First Name: Henry
I had to hand fit the Bosch 1617 to the old steel table and make a separate switch. The nice thing about this router is that it comes out of the base easily for bit change so the base itself can be totally fixed in place.
Also tried a little stair cap work and post covering with flat panels in this case. These were originally contractor steps that I tore out completely. The router and some good stile and rail bits can do alot of nice work.
Name:	Router Work 010.jpg
Name:	Router Work 013.jpg
Name:	Router Work 014.jpg
ccmnova is offline
post #5 of 22 (permalink) Old 11-21-2009, 10:43 PM
I will add
the second WOW. I use the vertical bits also only in a hrizontal table. And I use the 3 1/2 hps Bousch.
vikingcraftsman is offline
post #6 of 22 (permalink) Old 11-21-2009, 11:13 PM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Really nice work Henry.
Dave
the "Doctor"
Dr.Zook is offline
post #7 of 22 (permalink) Old 11-22-2009, 01:01 AM
BigJimAK's Avatar
Beautiful work, Henry.. You're a great inspiration!
BigJimAK is offline
post #8 of 22 (permalink) Old 11-22-2009, 12:53 PM
CanuckGal's Avatar
First Name: Deb
That fireplace is spectacular! The cabinet is gorgeous too. Very nice work!
I measured, I marked, I cut.
CanuckGal is offline
post #9 of 22 (permalink) Old 11-22-2009, 03:21 PM
RStaron's Avatar
First Name: Ron
Nice work Henry!!! I love the cabinet. Thanks for the input on how you made the raised panels, I was wondering how good the vertical panel bits were. What brand bit did you use?
RStaron is offline
post #10 of 22 (permalink) Old 11-22-2009, 03:51 PM Thread Starter
First Name: Henry
I have been buying bits for a long time - got out the raised panel bit I used and it says "craftsman" on the shank. Funny, I didn't think craftsman made these type of bits. I do see alot of makers now for vertical raised panel bits. It's a two flute cutter and the only thing I note is that you have to take multiple passes but you can run at the max rpm for good cuts. You need a high fence, and a cut out around the bit that you make with the bit itself helps. This bit, together with the stile and rail set I have, have allowed me to make some nice stuff !
Name:	Router Work 016.jpg
ccmnova is offline
Wainscoting Raised Panel jerry45 New Member Introductions 3 08-11-2009 08:56 PM
Raised Panel Bit rmaxa Router Bits - Types and Usage 3 09-13-2006 09:56 AM
What size of Raised Panel Bit? SandyT Table-mounted Routing 29 07-17-2006 10:34 PM
