Frued 3000vce for under mount - Router Forums
post #1 of 8 (permalink) Old 12-08-2009, 10:06 AM Thread Starter
Default Frued 3000vce for under mount
Hi Im new to the forums and was wondering if anyone has mounted the freud 3000vce in a table.I have been looking for a 3 1/4 hp plunge router to use both in a router table and out.This one caught my eye because of the above table height adjustment.The only thing is a can not find alot of feedback on it..any help would be appreciated or any other recommendation would be help
Thanks, Tom
traommy is offline
post #2 of 8 (permalink) Old 12-09-2009, 06:06 PM
dutchman 46's Avatar
First Name: Howard
Hello Tom: Welcome to the forum, Hopefully, someone will be able to answer your questions!
John 3:16
dutchman 46 is offline
post #3 of 8 (permalink) Old 12-09-2009, 06:18 PM
Thanks, Tom
Hi Tom, welcome to the forum.
I'm pretty sure a couple of guys in here have the 3000 table mounted. Looks like a nice router and they don't seem to be terribly high priced either. I have two of it's baby brothers, one for the table and one for hand work. Pretty happy with both except the plunge mechanism on the 1700 likes to hang up a little more than I think it should.
John Schaben
jschaben is offline
post #4 of 8 (permalink) Old 12-10-2009, 07:55 AM Thread Starter
Thanks guys, Im just really curious about the built in above table height ajustment.
Tom
traommy is offline
post #5 of 8 (permalink) Old 12-11-2009, 10:15 AM
I've got one ! I've just gotten it set up and usable, it takes a 10 mm hex (allen wrench) to adjust the height. I am going to use a long hex bit and ratchet (so it clears the fence) for adjusting. Also,the same hex size is used to lock the shaft when changing bits (from above) I'm quite happy with it.
bw
bwarner is offline
post #6 of 8 (permalink) Old 12-11-2009, 10:50 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Hello Tom, and welcome to the RouterForums. Thanks for becoming a member.
Dave
the "Doctor"
Dr.Zook is offline
post #7 of 8 (permalink) Old 12-11-2009, 11:23 AM Thread Starter
bw
Thanks thats what I was hoping to hear now I think Im gonna pull the trigger a buy one already!!
Tommy
traommy is offline
post #8 of 8 (permalink) Old 12-11-2009, 11:24 AM Thread Starter
Thanks doc
traommy is offline
can't get router to mount to table fatigueddiynut Table-mounted Routing 6 11-05-2009 10:09 PM
Using skis to mount router??? xvimbi Table-mounted Routing 28 10-12-2009 06:09 AM
How do I mount a Router to a table demaX Table-mounted Routing 3 04-16-2009 06:56 AM
Quick change router mount? archangel Table-mounted Routing 12 01-17-2008 01:51 PM
Table mount routers... Bluegillman General Routing 1 12-02-2004 09:37 AM
