About the Table's Fence... - Router Forums
post #1 of 15 (permalink) Old 12-08-2009, 06:42 PM Thread Starter
First Name: Marshall
Question About the Table's Fence...
I'm building a new RT with a piece of granite that I aquired freely, and wanted to inquire about the forum's fence experience.
What are the pro's v con's of having a side mounted fence, like with a table saw, versus a fence that has 2 pivot points (slotted or tracked, normal fence arrangement)?
The only experience I have is w/my table that incorporates the TS fence that it's built into...I like it, and don't know when I'd need to have a fence with two adjustment points...
I don't want to cut tracks or slots in the RT top if I don't have too... hopefully this makes sense....
AUFAITHFUL is offline
post #2 of 15 (permalink) Old 12-08-2009, 07:46 PM
Ghidrah's Avatar
First Name: Ronald
The Router Workshop guys use C clamps to fix a, (I think it's phenolic) fence to the table and it works fine. They have bunches of propriety fences for pretty much every operation.
Granite would certainly handle clampage.
Ghidrah is offline
post #3 of 15 (permalink) Old 12-08-2009, 08:11 PM
Hi Marshall
The best fence I have is the swing fence, it has one pivot point most router jobs work well with type of fence,,at times it needs to be clamped back from the bit but that's a easy job from the over hang of the fence..
The swing fence makes it easy to change out the bit, swing it out and pop off the ring and switch it out..
post #4 of 15 (permalink) Old 12-08-2009, 08:19 PM
AxlMyk's Avatar
I've seen Bobs' fence and it really is cool.
You could make a fence as long as the table is wide and use C clamps too.
Anything straight, plumb, and adjustable will work.
AxlMyk is offline
post #5 of 15 (permalink) Old 12-08-2009, 08:46 PM
I have the same table as Bob & I like the adjustment with the pivot. I have never mounted the side clamps to it. I've only used the pivot. Very quick & easy. Can also change out the center zero clearance piece in the middle, just swing it out over the edge of the table & slide one out & the other in.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #6 of 15 (permalink) Old 12-08-2009, 08:54 PM
Hi James
Here's a small tip you don't need to swing it out over the edge,just slide it back a little bit and then loosen the black knobs on the back side of the fence pop out the old one,pop in the new one and your set to go....this a great tip if you have the Horiz. setup on the same table..
post #7 of 15 (permalink) Old 12-09-2009, 12:37 AM
Hi Bob. Are you talking about loosening the split fence & sliding it back a little to get the incert out?
Whittier, CA.
jlord is offline
post #8 of 15 (permalink) Old 12-09-2009, 09:13 AM
Hi
Yep you got it
post #9 of 15 (permalink) Old 12-10-2009, 08:49 PM Thread Starter
That's exactly what I was looking for. COOL Fence!
Thanks for the posts and the picture.
post #10 of 15 (permalink) Old 12-10-2009, 09:14 PM
Router Table Fence
Face Lift for the Router Fence bobj3 Jigs and Fixtures 8 04-07-2013 09:21 AM
Some Thoughts on Fence Control Gilbear Table-mounted Routing 21 04-16-2010 05:38 PM
Which material for fence onap Table-mounted Routing 25 04-23-2009 06:23 AM
Pivoting fence arc vs distance? Bogydave Table-mounted Routing 16 01-14-2009 08:49 PM
